vibration under load after cv axle replacement
Old Jan 17, 2015 | 05:00 PM
GRNMAXDMON's Avatar
So I went ahead and replaced both cv axles today and went for a test drive and now I get vibration from my car while driving? what gives?
Old Jan 17, 2015 | 05:08 PM
4DRZ's Avatar
If you bought aftermarket, depending on brand, im betting you bought Chinese parts that arent the same as OEM. Same thing happened to me...I ended up having the OEM ones rebuilt and the vibration was instantly gone upon re installing them. What brand did you buy because sometimes only OEM will work.
Old Jan 17, 2015 | 05:12 PM
george__'s Avatar
VIBRATION DAMPENERS ARE MISSING
okay I'm done
Old Jan 17, 2015 | 06:56 PM
GRNMAXDMON's Avatar
This is true. I bought a chinese brand called: ToughOne from advance auto parts. I compared both cv axles to my old ones and nothing obviously different but didnt see any tyype of vibration dampeners on any of the axles, old or new? I cant say if my old ones are in fact OEM or aftermarket as well?
Old Jan 17, 2015 | 07:24 PM
4DRZ's Avatar
The aftermarket axles are your issue. I promise you, after I had mine rebuilt, it was like a new car. Sent the ones I bought from Rock Auto back for a refund. They were great about the refund. Alot of places sell the inferior knock off brands.
Old Jan 18, 2015 | 07:47 AM
GRNMAXDMON's Avatar
So aside from having my old ones rebuilt; what brand cv axle new or reman should i look into?
Old Jan 18, 2015 | 09:39 AM
4DRZ's Avatar
None bro, a rebuild takes only a few hours if even that at your local ma & pa shop. Literally....trying to buy new ones is a waste of money. The OEM ones are tough...when parts wear out they are easily rebuilt. Cost me $20.00 for a local axle shop to repair mine.
Old Jan 18, 2015 | 04:36 PM
ac max 92's Avatar
The parts that go into re building are probably from china too unless your buying oem from the dealership.
Old Jan 18, 2015 | 07:03 PM
4DRZ's Avatar
While there is this possibility, it is the lesser of the evil imho. Fyi OEM axles from the dealership are roughly $500.00 each. However all I can do is share best practices/experiences. Feel free to go your own route.
Old Jan 19, 2015 | 03:34 AM
GRNMAXDMON's Avatar
I appreciate the responses on this issue. Thankfully i didnot dispose of my old ones. Off i go to rebuild my old ones and return these "TOUGHONE" POS Axles. Thanks guys!
Old Jan 21, 2015 | 10:15 AM
GRNMAXDMON's Avatar
So I had the axles rebuilt and reinstalled them back into my car. Vibration is gone but now it seems that I might have either a bad bearing on the wheel hub or the pass. side axle but i'll have to rotate tires first to rule them out. Gotta love 20+ year old cars!!!
Old Jan 21, 2015 | 07:54 PM
4DRZ's Avatar
Glad you got the axle part sorted...
Old Jan 22, 2015 | 04:31 PM
GRNMAXDMON's Avatar
Ok it turns out my front driver side wheel bearing is toast. So now on another mission.
Old Mar 6, 2015 | 01:54 PM
MrGone's Avatar
I know you already fixed it, but yeah, a few times I've replaced one to have a vibration. Just have to do the work twice :-/
The OEM ones are much higher quality, that said a lot of the parts counter ones are getting better. But yeah after a few go arounds I'd rather rebuild oem than deal with aftermarket. The bummer is aftermarket draws you in with the lifetime warranty and price and they tend to make the job cleaner/easier, Esp. if you burn through boots.
Old Mar 6, 2015 | 02:17 PM
James92SE's Avatar
2 VE's are better than one!
I had a vibration under load way back in the day on a cheapo axle I bought from Internetautomart. It drove me crazy
However, other than that I've used aftermarket ones on almost all of my other cars with zero issue. On my VE's I prefer rebuilds, but actually right now on both of my VE's I have aftermarket units and zero issues. Parts store lifetime warranties are very handy.
Another thing I've noticed is that the boots generally aren't any higher quality on rebuilds than the aftermarket units. And since it's always the boots wearing out first you're then stuck basically messing with the axles again one way or another with the same frequency whether you go rebuild vs aftermarket.
Old Mar 9, 2015 | 06:26 AM
Maximan190's Avatar
I am experiencing this same problem, driver side axle, and with the same brand (ToughOne from Advance)
Has anyone thought of having the aftermarket axles balanced to solve the vibration issue?
Old Mar 9, 2015 | 04:33 PM
MrGone's Avatar
I've always gone the route of trading them back in on warranty on that route, but that's actually not a half bad idea, and until recently, i thought custom driveshaft work would be much more expensive than it actually is.
vingodine
45
May 21, 2016 12:46 PM
boomerbrian
Nov 8, 2015 05:10 PM
kingw323
20
Oct 21, 2015 08:36 AM
Starrider
Sep 17, 2015 07:26 AM
PH98I30
Aug 20, 2015 04:25 PM
