can I use a sandwich plate?
I want to install a oil pressure guage. And working on my turbo project I know I'll need a oil return line. So can I use a universal oil filter sandwich plate with the oil guage n return line?
And I don't have to mess with factory oil sensor
The benefit of electric is you don't have to have an oil line running into your cabin. If you were asking me the measurement I'm not sure what specific measurement you're referring to. The stock pressure switch fitting is a somewhat goofy size (I can't remember the size offhand) which is why I had to use two adapters there. Most people just crossthread their new line into the stock threads but I wanted to use the correct threaded fittings.
Dan - I didn't even think to check for this stuff in SS, but that's a good idea. It was hard enough tracking down all these little fittings and adapters anyway though and don't recall seeing any SS options, but of course I wasn't looking either so may have just missed them.
Where's the turbo return line? I hope this isn't what you're using this small hose for! You really don't need a return line on an oil pressure reading device! You need 1 hose that incorporates a restrictor that's it! I don't know where the return line is dumping the oil but if it's the oil pan you never read the correct pressure!
My return setup is completely separate from the stuff in my pictures. My pictures only show the feed line going to the turbo
![Stick Out Tongue](https://maxima.org/forums/images/smilies/tongue.gif)
knight_yyz
11-01-2015 01:34 PM
