Low idle/Massive fuel consumption
Old Feb 28, 2015 | 10:38 AM
1LOW3RDGEN's Avatar
I have a 94 GXE SOHC...engine is completely stock other than a K&N filter... On cold startups the car barely wants to run cause the idle is so low...then when it's warmed up in parked, it seems a little high...like the idle it SHOULD be on cold start ups... I'm not really sure what these cars should be getting mileage wise, but I remember taking a trip awhile back and looking at my trip odometer and it reading around 368 miles? And I was damn near empty... Now I'm getting like 100 miles less than that if I'm lucky... Lol. I'm no mechanic... Lol and realize there could be many issues here but how likely that it's an Idle Air Control problem? Should I check that before looking into Mass air flows? Another thing too... I bought an IACV from RockAuto but when it arrived it looked nothing like the valve I have on my car...yet that is the only model they and sellers on Ebay sell NEW... I ended up returning it... The only models I have found that look similar are used and for sale on Ebay... Sorry for the novel... I'm stumped...just trying to figure this out...any help is greatly appreciated!! Thanks!!
Old Feb 28, 2015 | 11:06 AM
TonyJr's Avatar
Check tps
Old Feb 28, 2015 | 11:50 AM
1LOW3RDGEN's Avatar
Originally Posted by TonyJr
Check tps
I have already replaced that too...sucks cause its throwing no codes...or check engine light...
Old Feb 28, 2015 | 12:25 PM
TonyJr's Avatar
Check maf sensor
Old Apr 29, 2016 | 03:00 AM
jessi89max's Avatar
Check maf sensor
Check pcv valve
Old Apr 29, 2016 | 06:06 AM
ac max 92's Avatar
Have you checked for vacume leaks?
Old Jan 6, 2017 | 12:39 AM
That_93maxima's Avatar
mine does the same thing check your fuel rail for leaks mine is doing it because my fuel injector for cylinder 6 has a bad o ring which is making it leak
Old Jan 21, 2017 | 08:04 AM
arsonist63086's Avatar
you might try replacing the o2 sensor. as a bad o2 with bad readings would cause the ecu to run rich or lean . in your case rich since you fuel consumption is hi. other thing you can cgech is the coolent temp sensor, make sure the contacts are clean and no corrosion . pad cts will make the car run rich since it might think the car is still cold.
Old Jan 21, 2017 | 08:48 AM
DanNY's Avatar
Ad·min·is·tra·tor
my vote also on O2 sensor
Old Jan 22, 2017 | 03:14 PM
1LOW3RDGEN's Avatar
Haven't been here in awhile as the car has been down... thanks for the reply I will check this out.
Old Jan 22, 2017 | 03:17 PM
1LOW3RDGEN's Avatar
One of the first things I replaced was the o2...and went with a Bosch brand o2...
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
