intercooler installed pics
Old Apr 4, 2015 | 01:36 PM
TonyJr's Avatar
Here some pics of install.
https://i.imgur.com/W0VAzfB.jpg
https://i.imgur.com/uoojcXz.jpg
https://i.imgur.com/cj2KFBg.jpg
https://i.imgur.com/C3yfVAA.jpg
Old Apr 4, 2015 | 04:06 PM
James92SE's Avatar
2 VE's are better than one!
You don't want to straighten that up?
If you shorten that straight pipe on the passenger side a bit it looks like it should lift the passenger side of the intercooler up and make it straight.
Were you able to do that with the universal piping kit you bought? If so gotta say I'm pleasantly surprised
Old Apr 4, 2015 | 04:17 PM
Getting there but I would definitely do as James92SE said to straighten out the intercooler. Such an eyesore!!
Old Apr 4, 2015 | 05:34 PM
TonyJr's Avatar
Yep with universal kit. Thanks that's a great idea I'll make that change
Old Apr 4, 2015 | 07:55 PM
James92SE's Avatar
You should start embedding your pictures too rather than making us click and open them in new tabs
When you shorten that straight pipe that runs behind your passenger headlight, which will hopefully straighten up your intercooler, you should at the same time lower that pipe that runs under the radiator hose. The last thing you want is the hot radiator hose sitting on a charge pipe giving you massive heat soak and basically undermining all the work the intercooler just did. I was able to get about 1/2" clearance on my pipe under the radiator hose, and I also added some heat reflective tape there too.
How is your intercooler secured/mounted? Or do you have it just sitting there being held up from the charge pipes themselves?
You want to make sure you have a good 5 or 6 inches of straight pipe immediately prior to your MAF. Looks like with the current positioning you should be good to go with the straight section.
Old Apr 4, 2015 | 11:47 PM
TonyJr's Avatar
I dont know if i can embedded it from my cellphone.
Old Apr 5, 2015 | 06:38 AM
James92SE's Avatar
Sure you can I post all the time from my phone. All you do is add img tags around the URL.
The URL's you posted above. Just put [ I M G ] in front of the URL, and then put [ / I M G ] behind the URL. (Don't put any spaces at all, I just had to space it to get it to show up).
Old Apr 5, 2015 | 06:44 AM
James92SE's Avatar
Here's a visual example -
Your first URL, when you post it, add the tags at the beginning and at the very end. Like this:
Then that photo will show up inline on the thread like this:
Old Apr 5, 2015 | 08:45 AM
TonyJr's Avatar
[Img]
https://i.imgur.com/YTUFJJw.jpg[/img]
Old Apr 5, 2015 | 08:47 AM
TonyJr's Avatar
Old Apr 5, 2015 | 08:49 AM
TonyJr's Avatar
Old Apr 8, 2015 | 12:42 PM
CMax03's Avatar
Nice work Tony Jr....
Old Apr 8, 2015 | 06:57 PM
TonyJr's Avatar
Old Apr 9, 2015 | 07:56 AM
CMax03's Avatar
That intercooler is kinda on the small side.....
Old Apr 9, 2015 | 05:38 PM
gp540's Avatar
drool. cant wait to do mine soon, can you post your oil return i'm curious
Old May 4, 2015 | 03:09 AM
TonyJr's Avatar
Old May 4, 2015 | 03:11 AM
TonyJr's Avatar
Old May 4, 2015 | 03:12 AM
TonyJr's Avatar
Moving battery to the trunk
Old May 4, 2015 | 11:55 AM
James92SE's Avatar
Coming together for sure
Did you have to trim your radiator fan shroud? I relocated a couple of the fan support "beams" on mine with plastic weld
Old May 4, 2015 | 05:54 PM
TonyJr's Avatar
After a couple of adjustment pipe fits good. All with universal intercooler kit
MaxLife17
Jun 27, 2019 01:37 PM
Cotozic
Jun 28, 2017 08:01 PM
BkGreen97
Apr 2, 2016 05:47 AM
MaxLife17
Sep 8, 2015 02:36 PM
Johnny9595
Sep 3, 2015 05:18 AM
