Factory Recalls?????????
Does anyone know about recalls?
My 89GXE is rusting bad on the drivers side rear wheelwell,leaks gas when full,and the seatbelt anchor on the rear drivers side has broken free.
I`ve read that Nissan has a recall for this very same problem.
My question is,
1. How do I find out if mine has had this done (although I doubt it)
2. Is there a time or milage limit to this
I guess I should call a dealer too, but I`m a lazyass
Any info would be appreciated.
My question is,
Re: Factory Recalls?????????
take it to a dealer and let them run the vin through their computer. they should be able to tell you if it was done or not. If not you have to leave it with them for a few days to have it repaired and have
it repaired.
Even if it was repaired i suspect that you may be able to get it covered again because it was not done properly the second time either.
Fro
it repaired.
Fro
My question is,
My question is,
You can call Nissan at 1-800-647-7261, give them your VIN, and they'll tell you whether it was done on your car or not. There should be no time limit on it.
Tired of the knocking!!!
i visited the site above and i don't know about tha rest you guys, but i'm sending a complaint to them about the VTC's in 3rd gen Max's. I figure that if more than half of peoples cars are having this problem, then Nissan should be liable to fix it. I know its probably not that easy to get tha NHTSA to have them recall this expensive problem....but hey, worth giving it a shot.
Re: Re: Factory Recalls?????????
Originally posted by Shugarhi
im not 100% sure what you are asking for, but all of those problems you are having is just from poor upkeep from the car and wear and tear due to age
please do your research before you doubt people about their upkeep.
hey i went to the site to check it out cause my have a 90 max and since it's the same gen...i decided to check it out. you HAVE the problem that they're talking about...seatbelt and all.. http://www.nhtsa.dot.gov/cars/proble...s/central2.cfm
i went to the same thing that dave went to but the ID number sent me to the stanza...which is the same problem. i'm bringing mine to the dealership and having them fix it.
good luck!
good luck!
Thanks alot all.
The recall was never done on my MAX and they`re gonna fix it next week. I might have them touch up a few other places as well.
Now all I need is a recall for my digital dash and I`m in there.
Once I get all the bullsheet taken care of I can MAX it out, so to speak.
Anyway thanks again,LATE
bucketheadd
bucketheadd
my03maxima
Jul 28, 2024 07:40 AM
magiconthetire
Oct 26, 2015 09:03 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
