Needing some ELECTRICAL help
Old Jun 1, 2015 | 07:16 PM
ac max 92's Avatar
So i finally got around to installing an led kit for my door panels, dome and map lights etc. that i got from americaner which look awsome by the way and if i get this issue fixed maybe i can post some pics. so anyway all was well until i popped the trunk and pulled the little trunk lid buld to replace with a single led. When putting the led in it was getting dark so i was having some difficulty plugging it into the socket first putting the bulb prongs facing east and west then realizing it plugged in facing front to back if im making any sense. Then next thing i know the door lights i just installed are now out. My keyless entry went dead and my airbag light is on and my clock is out. Not to mention my stereo is out and im sure to go crazy with no tunes especially with a setup thats worth listening to with what i have sunk into it. I checked the room light fuse but that only does the map and dome light which is still good. I also checked the tail lamp fuze because my running lights are now also out but the tail lamps still work when i put the headlights on and all else seems to work fine. Im hoping it's just a fuse or something simple im over looking but any help would be very much appreciated. Thanks in advance guys. Hopefully i can get it solved easily. Im a little stumped as to why the airbag light is on
Old Jun 1, 2015 | 07:25 PM
Daniel VQ30life's Avatar
take a multimeter to every single fuse, it's faster than checking individual ones, start there and replace as necessary, hope that's all it is
Old Jun 1, 2015 | 07:42 PM
GRNMAXDMON's Avatar
Check the fusible link at your positive battery terminal. I had a similar issue where it seemed everything was dead inside the car.
Old Jun 1, 2015 | 07:47 PM
ac max 92's Avatar
You mean in the same fuze box at the drivers side fire wall where the engine control fuse is?
Old Jun 1, 2015 | 07:51 PM
GRNMAXDMON's Avatar
No, on the positive battery terminal. It's the red fusible link attached to the positive battery terminal with 2 plugs I believe.
Old Jun 1, 2015 | 07:59 PM
ac max 92's Avatar
O.k i think i know exactly what your talking about but how can you tell if theres a problem with it? Ive actually never even had to unplug that before. I believe theyre the exact same on the 4th gens too.
Old Jun 1, 2015 | 08:09 PM
GRNMAXDMON's Avatar
https://maxima.org/forums/3rd-genera...help-asap.html
Go to the link above.
Old Jun 1, 2015 | 08:40 PM
ac max 92's Avatar
Thanks GRNMAXDMON, I skimmed through it but i will read up a little more tomorrow. Im not sure if the fusible link is the issue but i will definately look into it. I don't have an aftermarket alarm but i also noticed the the factory security system isn't on either. This all seemed to have happened while replacing one trunk lid bulb in the dark
Old Jun 1, 2015 | 09:12 PM
DennisMik's Avatar
The trunk light is on a 10 amp fuse left column, 4th up from the bottom.
Also on this fuse is pretty much everything you say doesn't work: step lamps (lights in door), audio, power antenna, clock, air bag system, digital dash, auto air controls, theft system, digital touch entry, automatic seat belts, key illumination.
Old Jun 2, 2015 | 04:52 AM
ac max 92's Avatar
Awesome. Thanks Dennis. Wow that seems to be alot of accessories on one 10amp fuse. I will look at that tonight first thing when I get home from work. I thought maybe it would have been on the dome light fuse but when I checked it it was fine and my dome and map lights were o.k. What is the fuse labeled as? I figured I had checked the obvious ones but obviously I may have over looked the fuse you mentioned. I'll check it tonight and let you know if it's the culprit. Thanks again
Old Jun 2, 2015 | 05:07 AM
Hectic's Avatar
I pull that fuse sometimes when working on the car so the battery doesn't drain. Even if it's good, give it a wiggle or replace it, see what happens. Also, you say your running lights work but your tails don't, but they are on the same circuit. The Canadian models have daytime running lights, and I don't know off the head how exactly the control unit interacts with standard circuit, but on the US model, if the corner lights are on, your tail lights are on. I would probably look at the daytime control unit, or completely remove it. It's a waste of about 100 watts during daylight, and is prone to issues.
Old Jun 2, 2015 | 07:41 AM
DennisMik's Avatar
You post at 6:52 in the morning "when I get home from work". My sympathies.
I don't have the labels for the fuses, so I can't tell you what it is. What I can tell you is that it is 2 fuses above the dome light fuse.
Old Jun 2, 2015 | 08:11 AM
ac max 92's Avatar
Sorry. I hadn't stop to think we're in different time zones lol. Thanks again and I will post back to let you know.
Old Jun 2, 2015 | 10:06 AM
ac max 92's Avatar
I was home on lunch and just as you said that fuse was the culprit. Thanks again Dennis
CorollaULEV
30
Aug 9, 2021 08:11 PM
smplyamzng
Dec 13, 2015 01:19 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
TonyJr
Aug 20, 2015 12:14 AM
Samedi
Aug 13, 2015 04:05 PM
