300ZX Brake Upgrade
Old Feb 1, 2016 | 02:14 PM
xMARCsthespot11's Avatar
300ZX Brake Upgrade
I'm new to the forum and was hoping you guys could help me out. I'm redoing the brakes on my 1991 Maxima and while I was at It i thought I could do the famous "300zx big brake Upgrade" but I was wondering what exactly needs to be done and purchased?
Thanks!
Old Feb 1, 2016 | 02:59 PM
DanNY's Avatar
Ad·min·is·tra·tor
rotor, calipers, lines, adapter plates.
the first 3 are easy...the last one i'm not sure who else is making them now.
just a hint our brakes are the same as 4th gen ones...sooo if you find something that fits a 4th gen it will fit your car.
Old Feb 1, 2016 | 05:01 PM
My friend makes Z32 brackets. I'll forward him to this thread.
Old Feb 1, 2016 | 05:34 PM
James92SE's Avatar
2 VE's are better than one!
Z32 brackets to fit what rotors?
Over the years I know there have been Matt's kits which I want to say used like 6th gen rotors. And also Jeff's kits which of course used the 13" Cobra rotors.
I have the Z32 + Cobra rotor setup on my car. Been running it for at least a decade now with zero issues.
Old Feb 1, 2016 | 05:36 PM
imported_Nismo_max's Avatar
or this...
https://maxima.org/forums/advanced-s...-fits-16s.html
Old Feb 1, 2016 | 05:53 PM
12.6" rotors I believe. Hopefully he'll chime in.
Old Feb 4, 2016 | 11:39 AM
shaks's Avatar
Hi. I make a little adjusted copy of Matt's brackets.
They are used with 12.6" rotor from 6th gen Maxima and 30mm calipers
Old Feb 4, 2016 | 12:18 PM
ac max 92's Avatar
These will work on the 3rd gens? Just curious what are the cost on a set of these brackets?
Old Feb 5, 2016 | 11:48 AM
shaks's Avatar
As far as I was told, 3rd gen knuckle is the same as 4th gen. If that is true - these should work.
Doing the liquidation on last 3 sets I have, they are offered for 159 shipped with bolts and nuts for proper installation or 139 without them. 10.9 grade hardware for bolts and nuts, washers are 8.8 grade.
I have to check what colors I still have, should be black and red. They are aluminum anodized brackets.
shaks's Avatar
One of the members received these
Old Feb 5, 2016 | 06:24 PM
James92SE's Avatar
Originally Posted by The_Fixer
shaks why are you using my pictures??
jlynch
Mar 14, 2016 08:07 PM
Bash96
Jan 5, 2016 06:12 PM
4whln
Jan 5, 2016 02:24 PM
xenoiny
Dec 9, 2015 10:30 AM
