Fuel rail washers and spacers
Old Mar 16, 2016 | 08:56 PM
redhunter's Avatar
I'm pulling off the intake manifold for the 4th time over the life of my 91 to replace injectors and I have never been able to figure out the proper order of the fuel rail screw washers and spacers. I didn't record the order 10+ years ago when I replaced injectors the first time and I've probably been inconsistent in the order over subsequent repairs. Yes, I know you don't need to remove the fuel rail, but each time I've needed to for various other reasons or to dislodge a stuck injector.
My current guess from top to bottom is screwcap, lock washer, flat washer, spacer, fuel rail, spacer, flat washer, and then engine block. Also, one of the spacer fell into a black hole and I've used 2-3 flat washers with the same height as a replacement; any harm in this?
Old Mar 17, 2016 | 02:29 AM
Tiniform's Avatar
The teflon type spacer is between engine and fuel rail. In other words, the rail tightens onto it - that's how I remember it.
Old Mar 17, 2016 | 06:10 AM
DanNY's Avatar
Ad·min·is·tra·tor
use the plastic spacers...they are suppose to compress a little when you tighten them down. this will ensure you have the proper seal on the injectors.
Old Mar 17, 2016 | 05:20 PM
redhunter's Avatar
Looks like the FSM EM-6 has it screwcap, lock washer, flat washer, spacer, fuel rail, flat washer, spacer and engine block. The FSM didn't have the torque specs for the fuel rail bolt, but it seems other posts on this site reference 2'lbs, which makes sense with the plastic spacers—I've cracked a few of them in the past thinking I needed to use typical torque given the size of the bolt.
ColdCananda
Apr 15, 2016 01:13 AM
ColdCananda
Feb 16, 2016 03:50 PM
cardana24
Feb 12, 2016 09:45 AM
A36-SR
Feb 2, 2016 06:51 PM
bloodthirstyemu
24
Jan 13, 2016 03:32 PM
