Opps, wrong torque spec
Old Sep 3, 2016 | 04:40 PM
kcidmil's Avatar
So after many years of putting it off, I finally got around to putting it all back together. A good side note for anyone trying this with the Chiltons, make sure you're reading the specs for the right motor. Off to the machine shop to make sure I didn't warp it.
Old Sep 22, 2016 | 08:58 AM
arsonist63086's Avatar
you won't warp the head if you over torque it . you will just break bolts lol. the worst case is once you install the engine and run it over time you will end up having to replace the head gasket since you basically got rid of its expansion/flex space by over tightening it.
Old Sep 22, 2016 | 04:33 PM
James92SE's Avatar
2 VE's are better than one!
Wow you must have put some serious torque into that head bolt to snap it. What's the VG intended spec and what did you actually torque it to?
Old Sep 29, 2016 | 08:14 PM
kcidmil's Avatar
46 ft lbs for the VG, 90 ft lbs for the VE. VG torque sequence diagram is on the same page as the VE torque steps.
I got one bolt to the 90 ft lbs and was working on the second when it snapped. Luckily where I work we have a machinist and everything checked out fine.
MADMAXA33
23
Jun 27, 2017 09:34 AM
DuaLMaGz
Sep 1, 2016 06:18 PM
jzack
Aug 26, 2016 03:26 PM
pjgreek
Aug 17, 2016 08:23 PM
Maxima 97 SE
22
Aug 10, 2016 11:00 AM
