Are there any good after market coil packs?
Old Aug 29, 2016 | 07:34 PM
MADMAXA33's Avatar
I have a code P1320 that just popped up on my 2000 SE and was planning on replacing my coil packs any way as well as the coil condenser and was curious if there are any good after market coil packs? I have already replaced the spark plugs and I'm going to ohm out wire harness and check the connectors as soon as I get a chance due to rain.
Any suggestions?
Old Aug 29, 2016 | 07:42 PM
nestorlugo's Avatar
I got some good oem coils hmu!
Old Aug 30, 2016 | 05:43 AM
Prophecy99's Avatar
simple and only answer no
Old Aug 30, 2016 | 05:25 PM
BigLou55's Avatar
+1
used OEM coils are better than brand new aftermarket ones. Its hit or miss when you go with aftermarket coils, mostly a miss IMO.
Old Aug 30, 2016 | 07:24 PM
maxiiiboy's Avatar
You can get the OEM Hitachi coils at a very decent price here: http://www.rockauto.com/en/moreinfo....359222&jsn=359
Old Aug 30, 2016 | 07:31 PM
Donkeypunch's Avatar
I got durolast from orailys 3 years ago. Still working good. idk why u guys think just cuz it's a maxima anything aftermarket doesn't last 1 month.
Old Aug 31, 2016 | 11:12 AM
Reallyslowrio's Avatar
Well, oreilly doesn't sell duralast for one.
2; my old vq30 4th gen threw a check engine light when I used an Autozone coil pack. The car ran fine, but the impedance caused a cel.
The vq35 seems to be less picky when it comes to coils, but OEM is still king.
Old Sep 1, 2016 | 06:13 AM
TallTom's Avatar
I have Hitachi for over two years and they have been excellent. OEM supplier.
Old Sep 1, 2016 | 03:45 PM
mclasser's Avatar
Old Sep 1, 2016 | 03:47 PM
mclasser's Avatar
Old Sep 1, 2016 | 06:08 PM
george__'s Avatar
hitachi brand
used oem
Old Sep 6, 2016 | 09:25 AM
Prophecy99's Avatar
well, at least for most if not all sensors on this car aftermarket are garbage and dont last the test of time like oem sensors, i thought it would ring true with coil packs being such a vital electronic part of the engine but... i guess not..
they can be pricey so for what they are worth i can see why its worth trying them if it isn't written in stone they suck, it just that it applies to so many other things on this car its almost a default.
in closing, you get what you pay for just saying.
Old Sep 6, 2016 | 09:41 AM
DennisMik's Avatar
So you're saying that the set of six ignition coils I bought on e-bay are not quality?
I'm shocked.
Old Sep 7, 2016 | 09:12 AM
Prophecy99's Avatar
im not sure how much sarcasm is there, but parts on ebay are scarey, and sensors and important parts at that are even scarier.
the last few parts i got on ebay was a FSTB in 2007, an evap sensor in 2009, and eyelids from a member here that used ebay as a platform for his sales.
i usually do amazon now, or real parts stores that are local (aftermarket or not)
bah blah blah, but i take ur opinion very highly , so if u are rockin aftermarket coils then +1
Old Sep 10, 2016 | 04:20 PM
MADMAXA33's Avatar
Thanks for the input guys. I think I'm going to buy some Hitachi OEM from Rockauto for$35.79 each.
Old Jun 26, 2017 | 06:12 AM
Prophecy99's Avatar
I'm shocked.
Dennis,
were these hitachi coils?
i need a coil asap.
Old Jun 26, 2017 | 07:29 AM
Derrick2k2SE's Avatar
You can't go wrong with Hitachi Parts.
They're made in Japan and are the OEM manufacturer for many car brands.
Old Jun 26, 2017 | 01:10 PM
Prophecy99's Avatar
thanks, is there anything i should know before allowing a shop to do this ?
i have misfire in cylinder # 2, upgraded to 6th gen vc's 90k miles ago,
Old Jun 26, 2017 | 03:31 PM
maximatech12's Avatar
Good choice! Hitachi is who manufactured the original maxima ECU!
So id say anything Hitachi is the proper rated electric output/input!
Id say the issue with other manufacturers is they might rate the sensor at a higher amp range? They may build the sensor for A 15 amp curcuit instead of the 10amp circuit its actually rated at. So that may be why some dont work right?
I see Unisia on some of the parts like the MAF.
Old Jun 26, 2017 | 05:47 PM
You can swap the #2 coil your self. You just remove the engine cover and remove the coil with one 10mm bolt. It's super easy. The coils on the 02 have proven to be pretty stout. I wouldn't replace them all (especially if you're paying to have it worked on) just for one misfire. You're looking at ~ $40 for one coil VS hundreds for a set of coils plus install.
Replace the suspected coil and see if the misfire goes away. Look at the plug as well. It may be fouled with unburned fuel.
Old Jun 27, 2017 | 08:04 AM
Prophecy99's Avatar
Cars at shop now, for state inspection, informed them to replace #2 cylinder coil with hitachi or OEM. thanks a ton Derrick, gonna PM you
Old Jun 27, 2017 | 08:29 AM
Prophecy99's Avatar
shops saying not Cylinder misfire code ! autozone 2 days ago said that, could have been maybe an old cold?
is it possible to have a misfire and have it go away phyiscally but store the memory with the CEL and codes?
Old Jun 27, 2017 | 08:44 AM
Oh yeah. A certain # of misfires in a period of time will throw a code. The code will stay for several drive cycles before clearing if it doesn't happen again.
Misfires can come and go. It's possible that it only misfired at full throttle after being hot for a while. If they pull the front 3 plugs and compare them they may be able to tell if it's been misfiring a lot.
A misfire can be caused by the plug, injector or coil. There are other causes but most will come with other codes.
Is this something that just happened or has it been going on for a while?
Also, how many miles on the plugs?
Any driveability issues?
Old Jun 27, 2017 | 09:34 AM
Prophecy99's Avatar
Thanks a ton for all that info !
I would say I noticed a very weird dump in acceleration (pedal on floor and super delayed and lagged reaction on highway one day, and it was noticable because i never had that with my maxima before , it always gets up and goes) but it was while on the highway between lanes and ramps and a heistation between cars and what not, and honestly no other noticable issues., and that was about a month ago.
I have had the CEL light on since january though cuz of EVAP gross leak, so its hard to pin point how long that misfire was...in there.
It is just coming up now because of an autozone scan [p0302] (being proactive prior to inspection today), but then while at shop for inspection 48 hrs later they said they didnt pull the cylinder #2 misfire code , just evap and thermostat, so i am going to leave it alone, i have had 6th gen vcs for 90k miles, and just did plugs about 20k miles ago.
considering my maintenance on this car I dont think i will worry about it unless it comes up again. the shop cleared the codes and is havin me come back thursday if the codes are gone to do emissions....fingers crossed.
Thanks again! will post updates (have an evap code [p0328] and a thermostat malfunciton code [pP0128] both kind of repeat offenders after caulking evap canister 5 years ago and staying cleared , and this thermostat code i did the ECTS and removed that code for 11 months untill may 2017)
shroom
Mar 24, 2016 06:06 PM
DuckSauce
Mar 8, 2016 04:05 PM
ZerotoSixty
29
Feb 29, 2016 05:13 AM
brandonj
Sep 14, 2000 03:56 PM
humaras
Aug 31, 2000 07:33 AM
