Part # confirmation
Old Oct 24, 2016 | 08:54 AM
ac max 92's Avatar
Part # confirmation
Can anyone confirm if part # 22060-30P00 is the correct part # for the oem vg knock sensor for the 3rd gen? If not would anyone happen to know the correct part # ?
Old Oct 24, 2016 | 04:58 PM
imported_Nismo_max's Avatar
Why dont you just go to z1 motorsport site and get the knock sensor and pigtail from the z32. I got it for my ve and it made a huge difference. Mine had a hair line crack and was corroded at the terminals. I dont think it was ever changed. here you go..98 bucks
https://www.z1motorsports.com/oxygen...ss-p-6932.html
Old Oct 25, 2016 | 02:42 AM
Hectic's Avatar
That is the correct part number. But that is a newer revision. The originals are 22060-56S10 (JECS) and 22060-59S00 (Mitsubishi).
Old Oct 26, 2016 | 07:22 AM
ac max 92's Avatar
Thanks ☺
Old Oct 26, 2016 | 07:30 AM
ac max 92's Avatar
Thanks. I have a new harness but figured i'd be better to go with an oem knock sensor rather than one from china for better reliability if i swap it out. Mind you the z1motorsports site says its an "upgraded harness" i wonder how is it different from the stock and why they consider it to be an upgraded version? My KS has never been done either. Were you getting a code on yours or did you just swap it out to see if there would be a difference performance wise? Also is the sensor the same for the ve and vg being i have a vg?
Old Oct 26, 2016 | 03:35 PM
for the vg just double check to see if your vg sub-harness is identical to the z1 motorsport one. Don't see why they would use different knock sensor. the z32 are a vg30de motor! but ig i would double check on that.
