What poor running conditions can "Code 13 engine temp circuit" be linked to?
Old Aug 10, 2020 | 01:02 PM
gerg's Avatar
Just curious what some of you have experienced with "Code 13/engine temp circuit". Hard start? No start? hot or cold start weirdness? Sporadic? Constant?
Thanks!
Old Oct 10, 2020 | 01:51 PM
gerg's Avatar
Just wanted to get back with report. Problem solved. Faulty crank angle sensor, replaced it. No code for it ever showed up. Thanks for the help.
Old Oct 23, 2020 | 09:03 AM
maxima278's Avatar
Just curious, when you refer to the crank angle sensor, which sensor are you referring to? The round one on the drivers side of the front valve cover? Or another one? I'm having similar issues.
Old Oct 28, 2020 | 11:33 AM
gerg's Avatar
The sensor is inside the distributor, not seen unless you remove the cap and a few components. Simple to replace, don’t have to remove the dizzy like some manuals say. Unfortunately, as of yesterday, I’m getting a code 11 & 21 (along with an ever lingering code13) and fear that my great deal on my New crank angle sensor may have Just bit the dust after only a month or so of driving. Not happy, ROCK AUTO.
Old Oct 28, 2020 | 07:41 PM
DanNY's Avatar
Ad·min·is·tra·tor
his VG is different than your VE motor.
front valve cover i believe is VTC.
the same sensor on your motor is more by the crank...i think...
saig
Jan 20, 2018 05:57 PM
bl513
Jan 3, 2001 07:23 AM
Imagination
Dec 26, 2000 07:21 AM
Pancor
Dec 8, 2000 04:48 AM
botzm
Nov 12, 2000 07:15 AM
