Anti-Theft alarm randomly after driving
I have a '90 SE. The anti-theft alarm often sounds a few minutes after driving, even if no one touches the car. It stops with the normal method; just open the driver door with the key.
If I just stop the alarm by opening the driver door with the key, then lock and close that door, it sometimes happens again a few minutes later.
If I open and firmly close all four doors, trunk lid, and hood, then that seems to fix the problem until the next time I drive.
I thought I'd just disable it by pulling the fuse. But it happened again a few minutes later even with the fuse gone. It's the 10a fuse that is located on the right hand side of the fuse box, third from bottom. BTW the fuse looks as good as new.
Any suggestions? I would like to just disable the anti-theft alarm.
Okay, I found the larger anti-theft fuse under the hood. I guess the smaller one under the dash is just for the dash indicator light?
I removed that larger anti-theft fuse under the hood. That definitely disabled it; now when I unlock the trunk with the key while the driver door is closed & locked, no alarm sounds.
Could that fuse be the problem? Is it possible to test it with a multi-meter?
You saw this post while driving?? I hope you make it home alive! ;-)
It's near the left front wheel. Look for a long brown plastic cover labeled Fuses. There are several fuses there. One of them labeled something like "A. Theft". You'll need a screwdriver or narrow key or something similar to release the latch to remove it.
Okay, this is crazy, but tonight the alarm sounded again! My wife had driven it about seven hours earlier. As usual, unlocking the driver door made it stop.
I then locked the doors and tested opening the trunk with the key, which always used to set it off. Nothing happened. So the removal of the fuse under the hood still seems to have at least some of the effect it I thought it had.
So now I'm thinking maybe there's a short somewhere in there. What wire do I need to cut or detach to make it stop?!?!?!?
James92SE
Aug 24, 2010 02:59 AM
sublunary
Apr 25, 2005 07:29 PM
