IACV Problems
Old Oct 22, 2020 | 05:46 PM
tmorales509's Avatar
IACV Problems
Does anyone know a way to fix this. My car started randomly dying out at idle. It will start back up but the idle will bounce around a bit and die out again. I had this problem before and it was the IACV and i think i got lucky and found one at a junk yard that time but last couple times i haven't had much luck finding cars like mine. It seems as that horse shoe shaped thing that goes over the sensor gets stripped out and it ends up coming off causing the car to not run right. What exactly does that clip do? Anyways i looked around online a bit but seems my options are pretty limited on replacing this part.
Old Oct 28, 2020 | 07:36 PM
DanNY's Avatar
Ad·min·is·tra·tor
VG motor right?
basically it's a stepper motor. turns one way to open and the other way to close.
that couples with the sandwich plate in front of it that opens and closes based on temp is what keeps the car idle going.
Old Nov 9, 2020 | 05:37 AM
CMax03's Avatar
Check the steel coolant line bolted to the intake manifold are clear and not full of corrosion and rust, stopping your coolant from reaching the wax pellet! It's pretty much works like a choke does!
dannydifalco
Sep 6, 2014 08:22 PM
2248
Jun 13, 2014 10:28 AM
Kaleobz
Apr 29, 2013 10:52 AM
monty31
19
Aug 27, 2006 04:25 PM
maximaintheface
Jul 21, 2006 04:14 PM
