Looking for 1991 Maxima SE ABS Delete Procedure
Old Mar 19, 2021 | 04:20 AM
Edmondlll's Avatar
My 1991 Maxima SE has the optional ABS. The ABS pump is leaking, a common problem. It can't be rebuilt and salvage parts have or will have the same problem. I want to delete the entire ABS system. Has anyone done it? I can get the required (1) master cylinder (2) brake booster and maybe (3) find someone to run new stainless steel brake lines. Questions: (1) has anybody done it; (2) what additional parts are needed; (3) know anybody in Northern Virginia who can do it, and (4) estimate cost.
Old May 10, 2021 | 06:52 PM
juggalo_g's Avatar
Im in the process of doing this but with the upgraded calipers z32 calipers but not the brake lines assuming ur using the stock calipers hard lines measured out roughly 16 ft for the driver rear and 24 feet passenger rear all brake lines are -3 3/16 brake lines m10x1.0 this should help you
This is the braking system
Old May 16, 2021 | 09:42 AM
Swap's Avatar
Will the car still pass the legal inspection if abs is deleted? The part is still available but expensive however.
Old May 18, 2021 | 07:20 AM
CMax03's Avatar
How will they know unless you make it obvious by bringing it to there attention! I've had all kind of performance enhancements for years and it always passed emissions and the visual inspection!
Old May 18, 2021 | 10:29 AM
Swap's Avatar
I thought the ABS light would turn on into the dashboard, just thought now the fuse could have been removed so no more light.
Makc1kNYC
Oct 1, 2011 08:49 PM
dr_rabias
May 27, 2011 10:25 PM
tonyinclearwater
71
Dec 7, 2010 07:05 PM
Logik
Dec 20, 2004 07:16 AM
xster
May 26, 2001 09:34 AM
