Speedo problem
Old Dec 21, 2022 | 09:39 PM
abunai's Avatar
Speedo problem
So the speedo works sometimes, other times it's just dead.
Also notices that the drivers side head light is coming on after the passengers side.
Related problem?????
Any suggestions????
1990
Old Dec 23, 2022 | 08:05 PM
LQ91SE's Avatar
The speedometer problem is probably bad solder joints on the speedometer circuit board. You can get a new cluster, or try to repair the solder joints on the board. Reflowing the solder requires soldering thru a magnifying glass because of the surface mount components on it.
Old Dec 23, 2022 | 10:07 PM
abunai's Avatar
I was thinking it was the board.
Trans shifts fine, and it uses the signal from the sender.
I have another gauge someplace.
Old Jan 8, 2023 | 10:14 PM
abunai's Avatar
I swapped the speedo head, and It's working fine.
Later I will see how hard it is to resolder the old speedo head.
Old Jan 11, 2023 | 05:06 PM
LQ91SE's Avatar
I used one of these to redo the solder joints:
Headset magnifier
Old Feb 21, 2023 | 01:59 PM
robbo7200's Avatar
i had this issue on my 89, i tried the solder points on the cluster, it did nothing. what did work, was taking a 17mm wrench and lightly hitting the vehicle speed sensor, and after that it worked for months on end, flawlessly. that one is free, so i'd say try that first before having it soldered.
Old Feb 21, 2023 | 05:08 PM
abunai's Avatar
Been working fine......so far.
I still want to try a solder the contacts, just because.
Old Feb 23, 2023 | 03:50 AM
LQ91SE's Avatar
Here’s a photo of the back of the circuit board
Speedometer circuit board
wmanimal
Jan 8, 2007 07:14 PM
piopremier
May 9, 2005 08:20 PM
03G35
Mar 9, 2004 10:36 AM
