Speedo problem???
Old Sep 2, 2025 | 11:15 AM
abunai's Avatar
Speedo problem???
1990 GXE, auto
So the speedo is acting up.
As soon as I start moving it goes up to 35-40mph.
Doesn't move unless I get to about 35mph then it starts to move, but is reading high.
Sometimes when I stop, it will go down to "o", but go up to 35mph as soon as I start moving.
Turn off the car, and it drops to "o".
Seems to drive and shift fine.
Could it be in need for a rebuild/repair, or could it be something else????
Speed sensor???
Loose wire/connector???
Old Sep 7, 2025 | 09:56 PM
LQ91SE's Avatar
I have fixed several speedometers by reflowing the solder on the speedometer circuit board. You must disassemble the instrument cluster, then touch up each solder joint by using a soldering iron thru a magnifying glass. If you are not comfortable doing that, an electronics repair shop should be able to do it.
Old Sep 7, 2025 | 11:25 PM
abunai's Avatar
I'll give it a try.
PDubs
Mar 16, 2011 11:08 PM
4dscPat
Nov 30, 2005 03:37 PM
elves
Apr 10, 2004 11:24 AM
NixMaxGLE
Jun 13, 2002 09:47 AM
StanVB
Jan 20, 2002 10:21 AM
