How does one remove the right side CV joint/half shaft?...
Old Feb 11, 2002 | 08:07 AM
G3Max's Avatar
Is it necessary to remove the 3 bolts to the mid bearing support?
Kevin
Old Feb 11, 2002 | 08:16 AM
bjyang
man...when i took mine off..it was a pain. the 3 bolts comes off easily..but i guess it was sooo old it rusted together. (the shaft and the ring) took a few days...even tried torching it but it only ruined it.
well...good luck with yours
Old Feb 11, 2002 | 09:24 AM
Jason92SE's Avatar
First jack the car up, and then remove the wheel. Then you need a 36mm deepwell socket to remove the large axle nut.Then remove the 3 carrier bearing bolts that support the axle.Last but not least remove the 3 bolts the hold the ball joint on, this will allow the brake and strut assembly to be moved out far enough the get the axle out.
Good Luck
Jason
Old Feb 11, 2002 | 01:13 PM
G3Max's Avatar
How do you go about removing the 3 carrier bearing bolts?
Its kinda tight. What tool did you use?
Kevin
Old Feb 11, 2002 | 01:39 PM
DanNY's Avatar
Ad·min·is·tra·tor
Re: How do you go about removing the 3 carrier bearing bolts?
Kevin
10mm bolts. get a box wrench. slap the close side on it...then get a hammer and tap the wrench until the bolt loosens up. take a little finess. if you're not too confident..best left to a pro.
The Frye
Sep 2, 2021 11:03 AM
Mar 12, 2020 12:06 AM
seesole
Sep 14, 2015 12:38 PM
conansriver
Sep 11, 2015 10:26 AM
Colossus
Sep 9, 2015 05:46 AM
