Car sputters
Old Feb 12, 2002 | 11:52 AM
SEguy182's Avatar
Car sputters
Yes i searched, but yesterday my car started to sputter at low rpms, when i get around 2-3k, the car surges and runs fine, but when i am stopped at a light or sign, it tries to die but never does. Any info would be appreciated.
Old Feb 12, 2002 | 12:14 PM
Badaxxima's Avatar
AAC valve. I can almost guarantee it. Check the thread "VE30de" in this forum. It's near the top. Look at my 2nd post.
Old Feb 12, 2002 | 12:17 PM
SEguy182's Avatar
thanks, has anyone replaced this? i searched, but it was for a ve, where is it on the vg?
Old Feb 12, 2002 | 04:10 PM
SEguy182's Avatar
i cleaned the pcv value and that helps it some, but its still there. Should i buy a new one? or does this sound like another problem, i couldnt find the aac valve
Old Feb 12, 2002 | 04:38 PM
Badaxxima's Avatar
Ah yes, the trickery of the Idle controller. I (my father and I) replaced the plugs, fuel filter, fuel pump and even cleaned the O2 sensor with WD40. All of these helped for about a day or so each. Yes go ahead and change it. Nismo1989 probably knows where they and what they look like on Nissan's. I'll shoot him an email. I'll try to get ahold of Matt93SE too, he'll definitely know.
-Justin
Old Feb 12, 2002 | 05:03 PM
Badaxxima's Avatar
Your Sig
I like your sig, I'm guessing you've seen Army of Darkness. That movie is hilarious.
Old Feb 12, 2002 | 06:27 PM
tilt's Avatar
for the vg, the aac valve is to the right of the tb and left of the air inlet tube. it's the round looking thing mounted on the front right side of the intake collector.
if you are going to replace it get a gasket too, chances are it will tear.
Old Feb 12, 2002 | 06:32 PM
Badaxxima's Avatar
With the black hose running down to the intake tract? I thought that was EGR related since it was before the throttle body.
Old Feb 12, 2002 | 07:08 PM
tilt's Avatar
yep, that's it. if i remember right, the egr valve is right under the aac.
Old Feb 12, 2002 | 08:06 PM
Matt93SE's Avatar
STFU n00b!
I know nothing.
Kaleb, Craig, or Bryan are the ones you want to talk to on the AAC valve.. I never touched mine.
Old Feb 13, 2002 | 01:17 AM
nismo1989's Avatar
Yeah, that's it. And yes, even if the gasket doesn't rip it needs to be replaced just like the throttle body gasket. Advance Auto Parts sells them.
Sorry I didn't understand what you were asking in your e:mail, Justin! I'll see you at noon or shortly after...
Old Mar 11, 2002 | 01:06 PM
CoolMax's Avatar
is invisible
Uh...what it the aac valve?
Do you guys with the problems have intakes?
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
altome15
Aug 10, 2015 07:05 PM
