What could be causing this?
Old Nov 15, 2000 | 07:33 PM
roman's Avatar
When I start my car in the morning and rev the engine a little I hear a gargling sound coming from the engine. Like there is water in there or something. After I rev it 2 or 4 times the sound goes away.
Anyone have any idea what it could be? The car runs fine but the sound is scaring me.
Roman
Old Nov 15, 2000 | 07:53 PM
perlmax90
i don't know what that is but i would get it checked out if i where you.
my car was making a noise for a long *** time and i didn't get it checked. then one day like 3 weeks later, i got tired of it and got it fixed. it was my power steering the high preasure line had a leak. now the noise wont go away. and just recently its been getting harder to turn my steering wheel.
Old Nov 15, 2000 | 08:10 PM
FAST4EN's Avatar
Re: i don't know what that is but i would get it checked out if i where you.
No don't worry about it....both of my maxes do that...it's just the water pump....nothing to worry about at all. Seriously. No problems unless it always does that...It's just getting water into the "system"
Old Nov 16, 2000 | 07:47 PM
Tick Tock's Avatar
Yes, likely coolant. I bled out the air and now mine is usually quiet. Small nut on top right side of engine by PCV.
Old Nov 16, 2000 | 08:44 PM
Matt93SE's Avatar
STFU n00b!
what that is is there's air in your cooling system.. as Tick Tock said, you can simply bleed the air out.. I didn't know where the screw was, but it's pretty simple.
you shouldn't just ignore the problem, because air in the system can promote corrosion on the internal engine parts where the antifreeze dries when the car is shut off.. not good.
Old Nov 17, 2000 | 11:51 AM
FAST4EN's Avatar
yeah i tried that and it stopped in my 92GXE but not in my 90SE....what does this mean? (it only does this for like 5 seconds when you first give it some gas[power])
Old Nov 17, 2000 | 01:41 PM
Matt93SE's Avatar
STFU n00b!
that means there's still a little mroe air in the system.
Old Nov 17, 2000 | 06:38 PM
FAST4EN's Avatar
oh ok...i'll try it and see what happens...thanks matt
Old Nov 18, 2000 | 04:12 PM
DDD
Hi Roman,
How are you old man?
Bleeding the cooling system is quite important. To do it you must untighten the bolt*** on the intake manifold, open a radiator cup and add some pure water until the coolant begins to flow out through the bolt's threads.
Make sure the engine isn't hot.
*** THE BOLT is near the PCV valve. Its threads is of 6 mm diameter. You can easily find it - it's "alone" on that flat spot on the manifold.
Good luck,
DDD
TKHanson
Nov 24, 2018 01:39 AM
mpbclutch33
Dec 26, 2015 11:11 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
