91 se suspension problem
Old Feb 15, 2002 | 09:40 PM
skatanic28's Avatar
ok i have a 91 se
whenever i make a sharp right turn or take one with speed, there is an audible knocking noise and a shudder in the steering wheel
there is no problem with the handling as it stays right on track
it feels like its in the front but the sound is coming from the back as well
my guess is a bushing or maybe even the sway bar
i looked under and as far as i could see there was nothing wrong
anyone have any ideas/suggestions
im gonna go to the dealer but im up at school right now so i cant
thanks for any help
Old Feb 16, 2002 | 01:39 AM
Bman's Avatar
Does it only happen on right turns? Maybe it's the CV joints? Check the boots for damage or leaking.
I suppose it could be a balljoint too, I had a car that did something similar, but the noise was mainly from the tires scrubbing...
Jack it up and check her out!
Old Feb 18, 2002 | 11:35 AM
Badaxxima's Avatar
Check your power steering fluid too.
Old Feb 18, 2002 | 02:04 PM
dontlikemymax
its the CV joints. everyone knows that!
if u think about it, what could possibly be making this noise other than the cv joint
Old Feb 18, 2002 | 02:34 PM
Badaxxima's Avatar
Case of Beer in the trunk.
Old Feb 18, 2002 | 02:50 PM
MaximusSe1991's Avatar
I had the same problem, it was the case of beer in the trunk. or the pile of speeding tickets in the golvebox. One of the two
Old Feb 19, 2002 | 04:22 AM
dontlikemymax
lol
yes. well if there is fluid leaking from the trunk your beers also need to be repaired or replaced!
Old Feb 19, 2002 | 06:38 AM
Matt93SE's Avatar
STFU n00b!
also check your wheel bearings. both of mine went bad recently, and they made some weeeeird sounds.
I even took it to the shop that rebuilt my tranny and he said it was either the differential inside the tranny, or the CV joint was bad. didn't even think about the wheel bearings.
do a search on wheel bearing (in message and title). you'll come up with lots of info about it.
Old Feb 19, 2002 | 10:46 AM
Badaxxima's Avatar
I heard muffler bearings can be a PITA too.
Old Feb 19, 2002 | 10:53 AM
dontlikemymax
yeah. i had that problem in my maxima. it cost a fortune to repair it.had to buy all 6 bearings!!
Old Feb 19, 2002 | 10:56 AM
Badaxxima's Avatar
Do you have a Macaroni Bent exhaust? I heard you were supposed to have one for each bend, so the pipes can flex easier. Just what I heard though...
Old Feb 20, 2002 | 04:50 AM
dontlikemymax
yes i have a macaroni ultra flex 2000 exhaust with
synchronized mufflers tuned in D minor.
Old Feb 23, 2002 | 01:39 PM
skatanic28's Avatar
so if its the cv, what exactly do i have to replace and about how much is this gonna be
thanks
Old Feb 23, 2002 | 03:10 PM
ThurzNite's Avatar
I've driven cars w/clicking cv joints, but none of them make the steering wheel shudder. Maybe your case is special?
I'd look into the bearings issue.
Jay
Old Feb 24, 2002 | 03:39 PM
dontlikemymax
thanks
just the cv joint.you take the boot away(id replace that too) then you can tap the joint off the axle using a hammer.you should be able to get an aftermarket joint on low prices but im not sure how low.
whope that helps.
Mar 12, 2020 12:06 AM
mikeg75
Nov 30, 2015 05:12 PM
Violator
Sep 9, 2015 10:14 AM
slowlifer
Sep 8, 2015 05:53 AM
A32goldylocks
Sep 2, 2015 06:39 AM
