My Antenna Is Stuck
Old Feb 16, 2002 | 05:59 PM
HAVS93 MAX's Avatar
My Antenna Is Stuck
I ALWAYS HERE THE MOTOR RUNNING BUT ANTENNA IS STUCK...
IM AFRAID THAT SOMEONE IS GOING TO BREAK IT...::?? CAN IT BE FIXED?
Old Feb 16, 2002 | 07:01 PM
Maximan190's Avatar
Re: My Antenna Is Stuck
yea mine did the same i just unhooked the antenna motor and left the antenna up until i feel like getting around to fixing it
Old Feb 16, 2002 | 09:51 PM
noleafclover's Avatar
everyone's is...no really though, it is a common problem. there are many replacements out there that you could get. you could go with a new motorized one, or any other kind.
Old Feb 16, 2002 | 09:53 PM
Shugarhi's Avatar
Re: Re: My Antenna Is Stuck
im not sure if this is the best solution but this is what i did... i pulled up the antenna so its fully out and then used a silicone spray on a rag to wipe it down to get the dirt off the antenna and to smooth it so it didnt get stuck, now it works fine
Old Feb 16, 2002 | 10:12 PM
Re: Re: Re: My Antenna Is Stuck
i tried that cause my friend's dad's car had that problem, but it didn't help on mine. so i don't know if i didn't lube it up enough or if it was just some other problem, but i hear the motor too.
Old Feb 16, 2002 | 11:17 PM
tilt's Avatar
your mast probably broke apart inside the sucker and thats why it's stuck but the motor is going
Old Feb 17, 2002 | 12:10 AM
crazy4maxima's Avatar
Yeah.... its kinda long process in taking out the right bolts of the seatbelt, taking off the carpet screws and then taking out the last screws behind the carpet next to where the jack goes... it not har just a pain.. Make sure that you push the attena down so that you are able to take the whole peice out... then its disconnect all the wiring and water drain hose.there is a big srew on the attena motor... if your lucky the plastic peice that makes the attenna go up and down might be off the gears... all you have to do is add more gear grease and make certain that all the gears and plasitc line move freely...
If you dont want to go through the hassle and think that the damn thing is broken just by a universal attenna.... but make sure that you disconnect the battery so that you wont blow a fuse or burn the motor.. I learned the hard way...ble that motor to the new attenna on my fathers 89 max.....
I will take some pics... My attenna was not working either since i bought the car in sept of 2001, and some kid around my neighborhood broke my atttenna in half.... Not really hard thing to do... but will take about 10-20 if your good with tools...
Old Feb 17, 2002 | 08:30 AM
Shugarhi's Avatar
ROFL: crazy4maxima, i LOVE your sig
Old Feb 17, 2002 | 10:57 AM
ghostmax's Avatar
I took my antenna apart in hopes of finding a broken piece of plastic inside. Didn't happen. I don't know what the problem is now since the mast was brand new when I bought it from the previous owner. The motor seems to run fine too. Just letting you all know that the problem is not always the broken mast.
Old Feb 17, 2002 | 01:27 PM
Jeff92se's Avatar
I'm needing a caw
Huh? Why did someone report this thread?
Old Feb 17, 2002 | 08:49 PM
maybe cause we have yet another lurker/newbie typing in all caps? i dono, it doesn't tell you who reported it? and they didn't give a reason?
Old Feb 22, 2002 | 09:54 PM
DMHedden's Avatar
I had the same problem. you can get an atenna mast from the dealer for about $30.00 and install it yourself. No need to pull out the entire motor. Just feed the plastic through until motor catches. This required 2 people to do. My 5 year old helped me. it was that easy. I hope this helps.
tarun900
19
Dec 20, 2021 06:57 PM
chisam14
Nov 6, 2018 08:56 PM
05RLS2
Apr 14, 2016 11:49 AM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
