If the rear section of a frame is rusted badly is it fixable?
I found a old 87 sentra hatchback or something for 250 OBO and its mint all around with 100k miles on it, New belts, Windshield and brakes but the guy said that its been sitting in a field for a long time and when he went to jack up the rear the frame started to cave in because of the jack and rust. Is this expensive fix? What will happen from driving around like this? OK this is maxima related because this will be a relief car for my poor max. I deliver papers to pay for college and the max modds and my Grand Cherokee payments and my work car(CHEVY celebrity Wagon)tranny is dieing(only have 1rst gear for the last 3000 Miles) plus leaking. I just can't bear putting 100 miles a morning on my Max after putting so much money in to it. Do you think this nissan is worth $150 with the frame rust?
Thanks JD
Thanks JD
Re: If the rear section of a frame is rusted badly is it fixable?
" when he went to jack up the rear the frame started to cave in because of the jack and rust. Is this expensive fix? What will happen from driving around like this? "
Ummm...dude...if the frame started to cave......serious problems...serious money......
no.. that car is completely undriveable. if the rear of the frame is rusted bad enough that it collapsed on a jack, think of what'll happen to the car the first time you hit a pothole or speedbump. it'll fall apart.
leave that junker where it sits and find another beater somewhere else.
good luck.
good luck.
Stupid question time: He DID jack it up on a approved jacking point right?
For instance, my dad's old Accord has this hump on the spare tire well for jacking, but many cars don't. If jacking it up from the side, there are reinforced areas of the frame rails to use just infront of the wheel well. Did the place where he jacked it up look like it was meant to be?
Originally posted by Jeff92se
It doesn't have a frame. It uses an unibody construction. And this is what is rusting. RUN don't walk away from this deal
If the rust is definitely localized, _and_ you've got a friend who works in a body shop, it might be worth it. However, if the rust is well spread, or else you don't have access to cheap body work, then I'd say forget it. There are lots of cheap cars to be had if you can just afford to wait.
Huttig2009
09-25-2015 03:31 PM
FlaMark
25
08-28-2015 10:15 AM
