92 SE Auto wont start when warm
Old Feb 27, 2002 | 11:27 AM
dmedeiro
Hi, Guys
I have a 92 Maxima SE (auto) 162km/100miles
The Car will not start from a warm start.
Example drive it for 30mins or so , then park the car for a bit.
I have waited hours until the car will start, depending on the weather.
I have owned the car for 6mths now.
I have replace the TBS, Serviced the throttle-body, replaced the starter, new air, fuel and platinum plugs.
The Car also lacks power at times, and there is no pattern to this.
I have a mild case of the VTC problem,(as per my locate Nissan dealer)
would that cause my problem?
Has anyone else experience this problem.
The Car starts and runs fine, whenever I bring it to the dealers.
Any help would be great
Dave
Old Feb 27, 2002 | 06:33 PM
eric93SE's Avatar
You should increase your base idle ~100rpm. I'm pretty confident that this will solve the problem.
Old Feb 28, 2002 | 05:04 AM
dmedeiro
Just to add to my original post.
The Car will start from a warm start when the weather is cold,
But not will the weather is warm.
Eric, How do I increase the idle speed by 100rpm?
Dave
Old Feb 28, 2002 | 10:41 AM
eric93SE's Avatar
There is a small phillips screw in the Idle air control valve, turning counterclockwise will raise the idle. I'll try and describe its location. The screw is flush with the IACV. It points toward the front of the car. It should be directly beneath the throttle body. With a long phillips head screw driver you should be able to reach it. Good luck
Old Feb 28, 2002 | 11:54 AM
Good Car's Avatar
ECU
Do you think it is nessary to turn ECU before you adjust idle speed?
Old Feb 28, 2002 | 03:59 PM
eric93SE's Avatar
Nope
Although there is a specific procedure to increase the base idle, but in his case he just needs to open the screw about 3/4 turn.
Old Feb 28, 2002 | 04:00 PM
dmedeiro
Hi,
Can you please tell me what the following means?
"Turn ECU before you adjust idle speed"
David
Old Feb 28, 2002 | 05:40 PM
Sudesh's Avatar
You can't even start the car in neutral when the engine is warm?
Hope your engine isn't secretly overheating or something.
Old Feb 28, 2002 | 06:30 PM
rhard49's Avatar
Hate to say it I had a similar problem the cpu board had a bad solder joint. When it got warm If I shut it off it would crank like crazy but never start. after it cooled down or the wheather changed and it was cold no problem.
Old Mar 1, 2002 | 05:25 AM
dmedeiro
Hi,
Does this mean I have to replace the CPU ?
Please advise
Old Mar 1, 2002 | 05:28 AM
dmedeiro
Hi,
How can I test this to make sure this is my problem?
Please advise
Old Mar 1, 2002 | 02:18 PM
eric93SE's Avatar
Originally posted by dmedeiro
Hi,
Please advise
NO, he was just asking if the computer should be RESET after changing the idle.
His problem is not a common one (having a cracked solder point in the ecu)
The only other thing I can suggest (other than raising the base idle) would be having the IACV (idle air control valve) cleaned out .
How many miles are on your max?
Old Mar 2, 2002 | 08:07 AM
dmedeiro
Hi, Eric
My car has 101,000 miles.
Would I be able to clean the IACV (idle air control valve)?
Would of that been part of a throttle body service?
Again
David
Old Mar 2, 2002 | 10:58 AM
eric93SE's Avatar
unfortunateley cleaning out the IACV would not be apart of a throttle body cleaning. Throttle body cleaning consists of just cleaning the butterfly valve of carbon deposits .
Some people on the org like to dissasemble their IACV. Personally I have a simpler method that involves spraying throttle body cleaner through the air intake that leads to the IACV.
http://forums.maxima.org/showthread.php?threadid=99296
Also your engine has alot of miles on it. Have you replaced any of the Ignition coils yet? (there are 6). If you have not I would reccomend replacing at least the three in the rear (or all of them if you have the $$$). they go for around $55 a piece from Courtesy Nissan in Texas (mention you are from the internet and you will get the discound).
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
trungg86
Sep 4, 2015 04:58 AM
