Blinkers and Hazards keep burning fuses!!!
Old Feb 27, 2002 | 02:32 PM
Statechamp
I recently had an aftermarket CD player installed in my car (without the Bose system).
Right after the instillation, the hazards and blinkers did not work. When the fuses were looked at, they were burned out. When a new fuse was put it (for either the hazards of the turn signals), it burned out as soon as the hazards or right blinker was engaged. The left blinker does not burn out the fuse.
I took it to the car instillation place and they confirmed that it was a short somewhere near the fuse box and that it had nothing to do with the stereo install. I am not 100% sure he is correct.
Has anyone heard of something like this?
Thanks for any help
Old Feb 27, 2002 | 02:48 PM
NOMAD92SE's Avatar
Re: Blinkers and Hazards keep burning fuses!!!
Thanks for any help
Check to see if the orange wire from Radio harness is connected to orange wire from aftermarket wiring harness. That will be your problem. I don't know exactly what the orange wire goes to but I have seen this before.
Old Feb 27, 2002 | 05:35 PM
Statechamp
Thanks, I will check the orange wire tonight and report back tomorrow.
I am sure that you are correct about the orange wire (since it almost definitely had something to do with the stereo instillation).
Old Feb 28, 2002 | 09:26 PM
Statechamp
Re: Re: Blinkers and Hazards keep burning fuses!!!
I took a look at the wires and the only orange wire that was on the original wire harness was connected to one of the rear speakers. I disconnected it and it made no difference.
Might it be a different color? I saw a red wire that had an orange timt (but I suspect that it is the power wire).
Any other suggestions?
Old Feb 28, 2002 | 09:29 PM
Statechamp
One thing I forgot to mention was that the instaler did not bypass the amp in the car and connected the head unit to the original wires that run to the amp (which just causes a lot of distortion). Might that have something to do with it?
Old Feb 28, 2002 | 11:06 PM
Schmoo
That's really quite odd. I'd suggest you take a good look at the hazard switch socket and plug and the wires going to it. I'd also suggest you get the blue Chilton manual and study the wiring diagram on page 6-133. I say your problem is really odd since the left and right turn signals are symmetric. It's difficult to see how you can have the problem with one side and not the other. Perhaps check the flasher unit (anybody know where it is?).
In any case, the wiring is really pretty straightforward. Power comes from the fuse panel to the hazard switch, then goes to the flasher unit. The turn signal switch and hazard switch can both hook the flasher output to the lights, which are all hooked together for the same side. From the lights the path then goes to ground.
Regarding the stereo wiring: does your head unit have line-level outs? Perhaps these should be fed to the rear amp instead of the speaker level outs? (I've got a Bose system, so I'm unfamiliar with the non-Bose setup; I'm assuming it's more standard.)
mclasser
22
Nov 12, 2020 01:58 PM
leatherneck
Sep 30, 2015 09:16 PM
homewrecker
Sep 24, 2015 07:01 PM
