Has anyone tried the venom module for our cars???
Old Mar 1, 2002 | 06:12 PM
cbrflyer919's Avatar
Hey I just wanted to see if any of you had tried the venom 400 module for our engines, does it work, what kind of gains did you see, and where have you found it cheapest? The best I've seen is about 340 shipped...
Old Mar 1, 2002 | 11:26 PM
PATRICK94SE's Avatar
Re: Has anyone tried the venom module for our cars???
Yo can do the same thing the Venom does for free by adjusting your T.P.S.(I have never done this on a third gen, but I am sure it is for the most part the same as most cars)
.....or just going W.O.T.
Old Mar 1, 2002 | 11:29 PM
Dummy's Avatar
the venom 400 only increases power at part throttle, no increase at WOT, so it is a waste of money unless you like pulling out of streets a bit faster.
Old Mar 2, 2002 | 12:50 AM
ICONOCLAST's Avatar
GET a JWT ECU upgrade and be done with it!
NO BS i swear I have noticed a huge difference since installing mine a few months ago and it is going to work, the Venom 400 sucks ***! take my word for it cause I have heard plenty of people especially several 4th gen ownes I know personally here in Lexingotn that had the Venom say it was a " Piece of Scheit"
Go Jim Wolf Tech Ecu all the way it is worth it!
Old Mar 2, 2002 | 01:41 AM
Dummy's Avatar
Re: GET a JWT ECU upgrade and be done with it!
what do you think you have gained, have you taken it to the track yet?
Old Mar 2, 2002 | 11:36 PM
ICONOCLAST's Avatar
Re: Re: GET a JWT ECU upgrade and be done with it!
I have not been to the track yet because my car is still in the midst of being upgraded. I still ahve to replace my wing, paint it, get new motor mounts, and deinately need to replace the clutch with a much stronger one now the stock one doesn't hold good enough with the upgrades I have (no joke). So before I go to the track I will be at least doing the motor mounts, Clutch & flywheel. The cutch and flywheel will be made by Mueller Fabrications for sure and I am hoping for a six puck or 4 puck spring center clutch with a 3500lbs pressure plate. then i can do my engine rebuild and definately a turbo.
Yes I am that die hard on the max.!
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
altome15
Aug 10, 2015 07:05 PM
