Clunking Noise in Rear when going over bumps
Old Mar 2, 2002 | 06:10 AM
spurgeonchapman's Avatar
93 Maxima maks a clunking noise from the rear when going over bumps. Rear struts just replaced but still makes the noise. Worse when the weather is cold. All bushings appear to be in good order and I cant see that the exhaust is hitting anything. This car is stock, no modifications have been made. Noise sounds like something banging around in the trunk but everything there including the spare is tight. Can anyone help figure this out?
Old Mar 2, 2002 | 07:03 AM
MaximaSpeedNYC's Avatar
Re: Clunking Noise in Rear when going over bumps
Sounds like your stabilizin bar is broken in the back, also check ur springs/shock absorbants. If you said when u hit bumps its like medal rattlin in ur trunk right? well if thats clear what u said, im 98.9% sure this is ur problem.
Old Mar 2, 2002 | 09:52 AM
WizzaMax's Avatar
Check the following...
Trunk torsion bar...mine always rattles
Top bolt of both rear shocks
Wing if you have one
Jack in brace tightly
Antennae assembly tight against side of trunk...can be hard to reach.
Old Mar 2, 2002 | 01:52 PM
Statechamp
I have the same noise coming from the rear of my car. Thanks for the info, guys.
Old Mar 3, 2002 | 05:11 AM
Thanks for the help. I will check out all of the suggestions and advise what I find. I had the rear struts replaced just last week and had the car realigned. So I don't think thats the problem but will check out anyway.
matts95max
Apr 23, 2025 10:44 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
doctorpullit
Sep 10, 2015 06:33 PM
jfl330
Sep 4, 2015 01:44 PM
