Still running like crap
Old Mar 9, 2002 | 06:37 AM
KiLer
ok....changed the Idle Position Sensor,changed the O2 Sensor and it still goes to stall at Idle while in gear....runs pretty good on the hiway but at a stand-still it hesitates and bucks...any ideas ?
92' single cam V6 Maxima
KiLer
Old Mar 9, 2002 | 11:26 AM
time2reup's Avatar
Re: Still running like crap
KiLer
Did you check your plugs and wires?
Old Mar 9, 2002 | 02:45 PM
KiLer
Re: Re: Still running like crap
there's no skip at all....doesn't sound like a cylinder isn't firing when it's in park or in gear.....it Idles around 600rpm in gear and then all of a sudden drops to 0. I just got back from a hour long drive and everything was fine...no problems.just the smell of gas when i started it after a 3 hour wait.ran fine though no hesitation or bucking...But I'm sure it will act up again when I go out later.
KiLer
Old Mar 9, 2002 | 02:50 PM
Jeff92se's Avatar
I'm needing a caw
Well the gas smell is probably your fuel lines leaking. Check and replace as needed
Old Mar 9, 2002 | 03:17 PM
skatanic28's Avatar
my car was doin the same thing before
i had just gotten new fuel rails, and used a different type of gas
it went away after about i week
i used a fuel system cleaner, i dont know if that made a difference
hope ur problems goes away too
captchaos
Mar 15, 2016 12:18 PM
londonflu
40
Sep 25, 2015 09:11 AM
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
ballerchris510
Sep 10, 2015 09:35 PM
