overdrive?
[QUOTE]Originally posted by catman316
what do you mean by on and off
ON= The orange ligth on
OFF= The orannge ligth off
Rigth or wrong? [QUOTE]
Overdrive ON = Overdrive OFF
Overdrive OFF = Overdrive ON
orange light = no light
no light = orange light
left = right
right = left
me = tired and confused
tired and confused = me
goodnight = goodnight
Originally posted by maxse91
Overdrive OFF = orange light
Overdrive ON = no light
left = right
right = left
left = right
right = left
left = right
right = left
a=0
b=1
ab=a^2
(ab)/a=(a^2)/a
b=a
1=0
Originally posted by Maximajism94se
how can you raise a to the second power when b only equals 1? and yes im ab a math nerd when i grow up...good job
Originally posted by Taegost
Value of b means nothing... Because 0*1 = 0... 0^2 = 0
whoa, I think you all are getting way ahead here...
Overdrive OFF = you are basically taking off your top gear...
I do this when I drive in the city and i KNOW i wont go over
45-50 MPH. This will help your transmission since it will
shift up/down a lot less.
When you take the OD off...there will
be a orange light on the dash.... letting you know that you have
decreased your gear ratio.
Overdrive ON = you want this on if you plan on going over 50 MPH
for extended periods of time, such as highway driving or even if
you drive 60 in a 45 constantly
After having to rebuild my tranny 4 mos. ago...I try to avoid strain
on the tranny by turning the OD off on short trips under 45 MPH.
hope that helps better than those math equations
I believe Chevy's also shift through (Not to, through) OD before reaching any other gear... Which causes more wear and tear.
I doubt Nissan goes thru OD to shift, and I dunno the technicalities behind shifting, but I DO know, that from a dead stop with OD off, it shifts to first gear a little faster, and has a little more power off the line, and when OD is on, sometimes it shifts a little hard into 1st when you punch it...
Just my observations tho
MarcJD
Jan 19, 2005 11:32 PM
