Odd idle characteristic.
Old Mar 26, 2002 | 02:11 PM
Badaxxima's Avatar
Okay, so I just changed my timing belt, drive belts, water pump, raised my idle to ~900RPM and advanced my timing to 18*BTDC. Car runs sooo much smoother now. I had to advance my cams 1/2 tooth past the timing marks on the rear upper timing cover to line up the timing marks on the cam sprockets with the white lines on the timing belt. Combine that with a K&N panel filter and the harshness/vibration at 4800+RPM is all but gone. My question is this, when idling, every 1-1.5 seconds, the engine will burp. Sounds like "buh" and the muffler will shake just barely. I think it's a small vacuum leak, because the exhaust will look/smell a bit rich when it happens and then be fine. Also, I'm going to replace the fuel filter and PCV valve this weekend. The car has basically never been touched except for oil changes, and I changed the plugs a few months ago. I'm looking at doing a full tune-up soon as well (TB cleaning time). It's been doing this for awhile. If anyone wants to do Cliff's Notes, feel free.
Old Mar 26, 2002 | 07:15 PM
Chris Gregg's Avatar
Get Off My Lawn
My max does this too. I'm thinking that just every once in a while one cylinder does not fire completely enough (or hot enough) to burn all the fuel injected into the chamber. Thus, you have a small miss and unburned fuel (which would explain the smell). Just a thought, probably wrong.
Old Mar 26, 2002 | 07:22 PM
Mikes90GXE
I get that too, but mine goes away when I put into drive. I figure that under load (in gear) the injector pulse lengthens giving more time for these old injectors to open properly and allowing a burnable amount of fuel into the cylinder. Otherwise I find no other reason for this to happen.
Old Mar 26, 2002 | 07:26 PM
Tom's Avatar
Tom
My car has done this for 72K miles now (since I got it at 65K). I never did figure it out. After replacing this and that over the years, but the car running exactly the same at idle, my only remaining guess is the fuel-injector O-rings.
Old Mar 26, 2002 | 08:48 PM
ChrisCheezer's Avatar
ok im getting that problem too
but mine is 10 thousand times the problems you guys are having,BLACK smoke comes from the tailpipe sometimes and its not oil the idel is soo bad its like 500 rpms and the almost stalls
----im gonig to have a FULL tune-up at the dealer in NJ ill tell you guys if it gets fixed..
Old Apr 7, 2002 | 12:09 AM
MadMaxBrent's Avatar
My money would be on the panel filter causing the problem. Put a standard filter in and the problem goes away. It appears with the panel filter it causes turbulance arounf the air flow sensor which causes the car to run lean and then the ECU compensates causing the rich mixture smell you talk of. Go to a CAI or pop charger type set-up and it should go away.
Brent.
Old Apr 7, 2002 | 03:18 AM
lp's Avatar
lp
I agree with Brent, ditch the K&N panel.
Old Apr 7, 2002 | 01:13 PM
pimpofbrooklyn's Avatar
Re: Odd idle characteristic.
I had the same problem. I bought a K&N Filter and the car was doing the same thing. I bought an inexpensive generic filter and the problem was gone.
Old Apr 7, 2002 | 05:22 PM
eric93SE's Avatar
the K&N air filter does not make the air more turbulent. It is oiled, so the oil is deposited on the tungsten element in the MAFS and this sends bad readings to the computer.
Just this past week I pulled all the injectors and replaced all the o-rings and seals and pintle caps and cleaned the filter screens. I must say it has made a difference, the engine missing problem has gone away, no more buh buh in the exhaust. When inspecting the injectors I could see which were leaking (although I would have like to have done a power balance test before hand, but did not have the $$). I have now 84,000 miles on it and The filter screens were pretty dirty. Last year I put in a K$N fuel filter that can be dissasembled and cleaned (SS filter element), I hope this will help insure cleaner filter screens for the future.
Old Apr 7, 2002 | 09:15 PM
lp's Avatar
lp
Quite a few VG owners have experienced an unstable idle after fitting the K&N panel filter. When its replaced with either a standard paper panel or CAI/POP type intake the idle often smooths out again, regardless of whether the MAF/screen is cleaned or not. Strange but true.
Old Apr 8, 2002 | 02:01 AM
Yup, that's what happened with mine. The distributor for the K&N panel said it does happen with some cars. You could modify the airbox to reduce turbulance I suppose, but you might as well go to CAI if you are going to do that.
Brent.
Old Apr 8, 2002 | 10:59 AM
rcrdps's Avatar
One thing to also note: Advancing the ignition timing a good bit will usually give you a miss at idle. An MSD(which of course the VEs can't use) will smooth it out somewhat. I hope to try the HKS ignition someday.
Gene
Old Apr 8, 2002 | 02:05 PM
eric93SE's Avatar
IT'S NOT TURBULANT AIR
That's not what causes the trouble, and its not the MAFS screen which must be cleaned. It's the element in the center of the MAFS which is affected by the tiny oil particles which are carried out of the filter element. The tungsten element runs normally very hot and as it is cooled by air traveling across it, it is translated into a current, which is then sent to the computer in the form of a voltage singal. But if a small amount of oil is deposited on the element then when comming to an idle the element will be much hotter than it is supposed to be so the computer will set the air/fuel mixture incorectly.
Old Apr 10, 2002 | 03:41 AM
lp's Avatar
lp
Re: IT'S NOT TURBULANT AIR
That can be a problem, but not the cause of the problem in my own case. Facts are I could swap between the PR CAI or an OEM panel and it idled absolutely perfectly but throw in the K&N panel and it ran like *****, rev-burping and pretending to be a POS at every set of lights.
I never cleaned the MAF element once in 4 years of ownership, and later sold the car with an OEM panel fitted and a rock solid idle. The K&N panel was never over oiled, the car just plain didn't like using it.
Old Apr 10, 2002 | 02:07 PM
Badaxxima's Avatar
Hmm... Crazy stuff. I have a K&N panel, but it didn't seem to make the condition worse. Maybe I'll try some electrical contact cleaner as per Matt's advice.
Old Apr 10, 2002 | 02:13 PM
Jeff92se's Avatar
I'm needing a caw
Just try a cheapo $10 paper filter. My brother has a VG 5-sp. His car also did NOT like the K&N panel. Switched back to the paper the idle was fine. Then I bought an used cone filter and again, the idle was fine. I of course tried all 3 in my VE maxima. All 3 were fine. Very odd but very true and I've seen many of the same stories. It's NOT the K&N oil. Or the car would not run on the cone filters very well either.
Old Apr 23, 2002 | 03:47 PM
Badaxxima's Avatar
I was thinking about this the other day and I came up with a theory:
Since our filters sit at an angle, I wonder if the fibers in the K&N are straight or just close enough to each other to allow excess oil to flow down and pool some towards the bottom. This would allow a somewhat excessive buildup and possibly allow some of it to be sucked into the intake tract and onto the MAF. I doubt the condition would be similar with Popchargers since they are exposed to engine heat which would affect the oil, nor would their shape allow such easy flow toward the bottom. Thoughts?
Old Apr 24, 2002 | 03:42 AM
If it was oil, then if you removed the K&N and put any filter back in, the problem would be there because the sensor is coated in oil. VE's don't seem to mind the panel filter but don't they have a slightly different intake setup?
B.
TKHanson
Nov 24, 2018 01:39 AM
Unclejunebug
Apr 2, 2016 05:42 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
