Fog Light Installation, Help Needed
Old Mar 30, 2002 | 08:21 PM
Wink519
I got a set of Hella FF50 fog lights cause my 92 GXE never had any. Well my question is, what is the best way to run the wires into the cabin for the switch. Since my max never had fogs to begin with it,I am pretty sure there are no wires already in the car. Does anyone know of any exsisting holes in the firewall where I can run the wires through? Thanks.
Old Mar 30, 2002 | 09:05 PM
FFxI30's Avatar
You car is wired for Fog Lights. I added stock SE fogs to my GXE and its all with factory wires. If you follow the wire that plugs into you headlights you will see a little clip taped to the wire, this is your fog light clip. Then if you take apart your dash and look on the left hand side where there is a blank spot for another button you will see a wire harness taped to all the wire back there. All you will need to do then is buy a Relay for about $10 at any hardware store and figure out which wire is which on the clip and you will be set without running wires in your car. Let me know if you have any questions. Its pretty easy to do.
Old Mar 30, 2002 | 09:45 PM
JDwyer2821's Avatar
My 90 GXE had no foglight wires or any holes in the firewall I bought Nissan factory kit which gave me very detailed instruction on how to wire them up. I will try to look for them. It was not fun
EuroDriver
Sep 14, 2015 06:08 PM
TonyJr
Aug 20, 2015 12:14 AM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
98nismomax
Aug 13, 2015 12:44 PM
