fuel pressure regulator
I have a Stillen High Flow Intake in my 1992 Maxima SE 5-speed and I feel at low rpm's i'm running too lean and wanted to know if a fuel pressure regulator would fix this? If anyone knows what are the effects of a fuel pressure regulator?
Thanks,
D-sta
Thanks,
D-sta
Nope it wouldn't fix it at all. How do you know your running lean without a wide band o2 sensor? The thing to do is find a local dynojet center http://www.dynojet.com/lauto.shtml and have the car dynoed with the wide band o2 sensor. In the meantime try bumping the base timing to 19*BTDC http://www.geocities.com/craigbraceg...g/timing.html.
I think what you mean is you feel some low RPM power loss which is "normal" for a popcharger type intake. Unless you know something other than what you mentioned and this only started happening after you installed the intake, I wouldn't do anything about it..... also you should beware of giving advice on speculation BEFORE you know the answer (the Ram Air thread).
Originally posted by nismo1989
low rpm power loss?? I had low rpm power GAIN on ever car I've ever put a pop charger on. I had both on an Accord DX (pop and CAI) and the CAI took power from the low rpms. Why would you have a power loss from an intake that is less restrictive and has no cumbersome bending tubing, just straight flow to the MAF?? Please let me know, becuase this defys all I have concluded about the things...
cold air = more air
... doesn't make sense to me.
the long tubing also does have some effect to the performance. you can do a search on that too (cai tube/tubing) to find your answers. i recently posted a thread in the general maxima discussion focusing on just the tubing and how it affects performance a day or two ago.
I don't need to do a SEARCH on the gains from using various intakes. I can just do it as I have always done with cars for years. Engine types are a variable you are neglecting to take into consideration. I believe that is the reason for my misunderstanding, not being an idiot...
jmlee44
10-02-2022 02:13 PM
06-06-2017 02:01 PM
Forge277
06-13-2016 09:26 PM
