Need help from anyone who knows their way around a relay, for turn signal mod..
Old Apr 10, 2002 | 07:58 PM
cbrflyer919's Avatar
Wow, I'm learning all kind of things tonight. I love the org! I'm pretty knowledgeable with car electrical workings, but have never really grasped the specifics of verious relay wiring. I have sidemarker lights on my car now and they are wired to come on with my park lights (rice I now but I like it) and I would like them to blink off when I use the turn signals like on a honda. Anyone know how to wire this? Thanks
Old Apr 10, 2002 | 09:24 PM
«§»Craig B«§»'s Avatar
all you need to know and more on my how-to page
http://www.prism.gatech.edu/~gte671n/mymax.html
look in the corner rewire
just pretend the sidemarker is the little orange bulb and wire it that way
also, check out the page on how relays work and applications
good luck
Old Apr 11, 2002 | 10:46 AM
Okay, I understand how this will work with the park lights on from your diagram, but how about during the day, I want them to blink then too.
I rewired my buddies 2k max so that his turn signal and side light would blink simultaneously during the day, and then at night when the side light came on with the other park lights it would blink off, alternating from the turn signal. Thats what I want but cant figure it...Ideas???
Old Apr 11, 2002 | 03:19 PM
Sudesh's Avatar
If i'm correct you installed some aftermarket sidemarkers on your car and you would like them to blink when the turn signals blink.
The turn signal bulb is an 1157 (double filament), so there three wires going to the turn signal bulb, one ground and two power. One power for continuous on when you put the parking lights on, and one power wire to blink.
All I would do is wire the power wire from your sidemarkers to the wire power wire in the turn signals that blinks the turn signal. So that way your sidemarkers and turnsignals blink simultaneously.
Old Apr 11, 2002 | 05:26 PM
I appreciate it, but the turn signal is not an 1157, its an 1156 (single filament). Also, i know how to make it blink, I want it to do what my description says above. Someone healp please...
Old Apr 11, 2002 | 05:46 PM
noleafclover's Avatar
no...
signal is 1156 (that thing in your front bumper)
the cornering light of the side lamp (the big bulb in the corner light) is 1157, it is on with the P lights, and brighter with the signal (not blinking though, that's why it's called a cornering light, when you're turning at night, it lights up what you are turning into for you...) the side marker part of the light (the part that's yellow on OEM corners) is like 194, just for the info...
so no...
sorry, not wanting to sound rude, just in a bad mood
Old Apr 11, 2002 | 05:58 PM
alright, cybflyer, go there to read about how relays work...and/or go to howstuffworks.com and read what they got to say. then once you know how what you're doing works, you'll probably be able to do this...
what you'll need to do is have a relay that the power wire from the parking lights to the side marker goes through. this way when you have your lights on, the marker will come on. then run a wire spliced into the turnsignal + to the relay connect that will cause the lever inside the relay to disconnect the contact for your marker power wire. then just ground the relay and you should be good. hope that helps..sorry if it was confusing.
Old Apr 11, 2002 | 10:32 PM
did you read that page???
that how-to was up before the 2k max even came out
blinks during the day
comes on and then alternates blinking at night
easy peasy
Old Apr 13, 2002 | 09:58 AM
Craig did you get my mail?
I did your "corner rewire 1" and it works like you said it should via the hazard switch but nothing happens at all when I use the steering column switch, what happened? How do I make these work now?
easy peasy
Old Apr 13, 2002 | 11:52 AM
sorry I didn't respond to the email yet, I've been busy yesterday and this morning
that's pretty weird, maybe it's a fuse?
check over all the wiring again to be sure too
tarun900
19
Dec 20, 2021 06:57 PM
gavin68
Sep 18, 2021 12:36 PM
salty318
Sep 29, 2015 01:21 PM
