k&n filter
Old Apr 11, 2002 | 09:35 AM
phat's Avatar
k&n filter
I am thinking of installing a popcharger in my 92 ve. From the threads that I've read, there is a problem with the oil covering the maf sensor that kinda change the idle a bit. Any suggestion or recommendation? Is there a noticeable difference in the hp?
Old Apr 11, 2002 | 10:32 AM
rcrdps's Avatar
I think you're mixing two different problems. The free flowing K&N panel filter causes idle problems....on VG's(?) They say that any K&N will coat the MAF sensor,...and it won't be just the idle that gets messed up. Some say to just make sure not to over oil the filter and also let it dry. I think that's probably the key since I have seen quite a few K&N users(including myself) not have any problems.
Gene
Old Apr 11, 2002 | 02:27 PM
Bman's Avatar
I have a K&N panel filter and if anything this should be worse than a pop if there's to be problems. My idle is usually steady and the car (usually) drives fine. I really think it's because of overzealous oiling of the filters. Especially of filters right from the factory which some people have said have been DEFINITELY over-oiled. Just go sparingly but thoroughly and you should be okay.
Old Apr 11, 2002 | 03:16 PM
skatanic28's Avatar
i would have thought people over-oiled them, but the factory too?
mine didnt seem to bad and i got a tube before my maf anyway (cai)
so hopefully no problems come about
Old Apr 12, 2002 | 12:08 AM
kingrye's Avatar
i have a k&n panel and want to make a home adid pop charger has any ne doen this i want to cut the snorkel and a hole inthe bottom of my air box
Old Apr 12, 2002 | 02:24 AM
Bman's Avatar
Try using the search engine, it's been discussed before, if not recently... You can make a popcharger cheaply without cutting (destroying) anything.
Oh what the heck, here you go! $15 MAF adaptor + elcheapo 3" cone filter = DONE
There!
my03maxima
Jul 28, 2024 07:40 AM
Justin Kroll
Oct 1, 2015 07:03 PM
Redfox
Sep 28, 2015 10:41 AM
bumpypickle
Sep 20, 2015 08:22 AM
