rear valve cover and random stuff
![](https://maxima.org/forums/images/smilies/support.gif)
ok, finally decided to replace my rear valve cover gasket since i had the time and was wonderin if anybody ran into any probs...i have searched and couldnt find any negative coimments, but just checkin to make sure...also, do i really need to use a new intake gasket or can i just reseal the old 1? reason bein i was quoted $50 from a parts place, maybe the dealer is cheaper??? also, somtimes when i am crusuing at say 60+ i hear a droning and repeating noise...waaAAAHHaaahhh....waaAAHHaaahhhh...and keeps goin...its hard to explain, and isnt loud atall, if i have the radio on i don hear it atall, but i figured id mention it while i was talkin junk...also, would any1 b interested in a write up on replaceing the gasket? if so i will take pics, etc...maybe later
Haven't done it myself, but you DO need to get a new valve cover. usually a Fel-Pro kit is about $35 and includes everything you need, but may not be the case on our cars.. They were that much on a couple different honda engines I've done valve work on.
but anyway, you'll need the intake manifold gaskets, valve cover gaskets, and make sure you get the small round ones that fit around the spark plug holes. if you don't, you'll end up leaking oil into the spark plug holes and the car runs like crap. that's why I had to work on both hondas.. the plug holes filled with oil from leaking valve cover gaskets, and caused lots of other problems after that.
yep, i gots em...i tried finding the valve gasket at parts places, no help atall...had to get the 1 from the dealer and it has the middle part for the holes...actually thats my prob, i was changing my spark plugs, pulled out the ignition coil or whatever and drip, drip it went...at 1st i freaked i was like holy crap, but hopefully this shouldnt b 2 bad, saves me like 300 in labor to (considering it goes ok
) but i will get the intake gasket, ill go down to nissan today...thanx
![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
Matt93SE
04-08-2018 09:23 AM
Huttig2009
09-25-2015 03:31 PM
Nintensity
08-13-2015 05:41 PM
