intake manifold
Old Apr 17, 2002 | 07:49 PM
jaredb03's Avatar
intake manifold
how do you know if your intake manifold is bad or leaking? please help. thanks
Old Apr 17, 2002 | 08:18 PM
Matt93SE's Avatar
STFU n00b!
there will be a big crack in it and your engine will run like crap
Old Apr 17, 2002 | 08:32 PM
matt1sd's Avatar
good call.
Old Apr 19, 2002 | 06:31 AM
jaredb03's Avatar
were would the big crack be?
Old Apr 19, 2002 | 01:17 PM
babyboy's Avatar
Re: intake manifold
when i replaced my fuel injectors i had a leak in the intake manifold gasket that was small, but i notice the throttle response was horrible.
this is what i did to locate it. i bought a few cans of carb cleaner. turn the car on. with the plastic tube on the spray nozzle, i sprayed along anywhere i suspected a leak. the car will start to idle different once the carb cleaner is spayed over the leak. once you pinpoint where the leak is coming from, replace a gasket if applicable or try to fix the manifold. this worked for me so it should work for you. good luck
Old Apr 19, 2002 | 02:05 PM
Maximum5spd's Avatar
LOL
aw11power
Oct 10, 2021 04:57 AM
JonBlz
Oct 5, 2015 06:02 PM
maxima297
Sep 30, 2015 03:32 PM
MichMaxFan
Sep 30, 2015 09:18 AM
dshinn
Sep 26, 2015 08:07 PM
