Springs Question
Old Apr 17, 2002 | 10:21 PM
NixMaxGLE's Avatar
Springs Question
i am thinking about getting intrax springs from someone i know pretty soon. i was wondering what else i would probably need to get at the same time or soon after getting the springs on a 92 gxe w/ 160,000 miles on it. i'm more specifically asking about the struts and how everything stock would hold up after getting these springs. (i think they're about a 1.7 drop). thanks everyone
Old Apr 18, 2002 | 12:09 AM
kaleb's Avatar
As much as you won't want to hear it, here is what I recommend:
New struts (if you can afford Koni, get Koni)
Front upper strut mounting insulators
Front strut bearings
Front bump stops
Front dust covers
Front spring seat insulators
Rear bump stop/dust cover assembly
Rear upper strut mount insulators
Rear spring seat insulators
You can go aftermarket on the bump stops and dust covers if you want, stick with OEM on the mounting insulators and spring seat insulators (since that's the only way you can get them)
-Kaleb
Old Apr 18, 2002 | 12:32 AM
nismo1989's Avatar
Front bump stops
Front dust covers
-Kaleb
Wow, that's just about everything you could replace. With 160K, it's probably not a bad idea either...
If you can't afford Konis (they are pretty expensive and high performance) then go with the Tokicos. Don't go OEM and if your getting Intrax I don't recommend the KYBs either. Good advise, Kaleb.
Old Apr 18, 2002 | 01:47 PM
NixMaxGLE's Avatar
WOW, THATS A LOT OF STUFF I'D BE REPLACING...CAN ANYONE GIVE ME APPROXIMATE PRICES FOR EACH OF THOSE THINGS
THANKS
Old Apr 18, 2002 | 01:52 PM
Maximum5spd's Avatar
Re: Springs Question
I have a 89 SE with the exception of eibach and tokico every other part has been on there for probably years and years, (oh only axle boot i changed) , everything is just fine and dont have any problems what so ever well at least for now.
BkGreen97
Apr 2, 2016 05:47 AM
imported_Nismo_max
Feb 17, 2016 03:39 AM
pears
Sep 18, 2015 05:25 AM
Stagnet04
Sep 13, 2015 09:32 PM
Johnny9595
Sep 3, 2015 05:18 AM
