What do you all have your timing set to?
Old Nov 26, 2000 | 03:34 PM
Foo90SE
I see people have advanced their timing for better performance, what would be a good setting for my 90 SE? i have it set to 15 degrees right now.
Old Nov 26, 2000 | 04:32 PM
block's Avatar
i think 20. i havent gotten ahold of a timing gun yet but 20 is what Im gonna do.
Old Nov 26, 2000 | 05:00 PM
UndecidedMax's Avatar
what are you talking about
what are you talking about the timing... does it have somethin to do with the tranny? can i have some info on what your talking about, and how you change it?
thanks
Old Nov 26, 2000 | 05:05 PM
Foo90SE
Ignition timing...
changes when the spark occurs in the cylinders...if its off it can cause detonation or lack of power...nope dosnt have anything to do with the trans.
Old Nov 26, 2000 | 08:39 PM
Chris Gregg's Avatar
Get Off My Lawn
To clearify...look up the old posts for detailed info on doing the mod. Two: when setting the advancement, it is advanced TO 20 degrees, not 20 degrees over. I don't know the angle, but I'd say that far would come close to causing the plug to fire almost before it reaced top dead center! The oem timing is set to about 15 (mine was 16) so IMO you should go 5 over to 20, I went to 21. I tried the other suggestion of 8 over and it felt like I lost power. I inspected my plugs, and I saw signs of detonation though I couldn't hear it while running. So, I went to 21 and it has really picked up in the lower rpm's. Instead of picking up at around 3,500 rpm, it picks up around 2,500-3,000 and more aggressively! (5 speed)
Old Nov 26, 2000 | 09:28 PM
block's Avatar
mmm aggressive, looks like im doing the timing increase
Old Dec 1, 2000 | 10:15 PM
link please
is there a link where it shows and tells how i can learn how to do this mod.... thanks
Old Dec 1, 2000 | 10:44 PM
FitzMax's Avatar
Re: link please
Yeah I hate the lag that is there on my 5 spd until I hit like 3000-3500 rpms. I need it to be quikier in the low end. Links please!!!!
Old Dec 2, 2000 | 04:33 AM
Foo90SE
If ya got a Haynes manual it'll tell u how to set ignition timing in the tune up and maint. section. Requires a timing light and a 12mm socket/ratchet. If u have the light its simple. If u dont know what a timing is, ill post a more detailed thing later(gotta go take my SAT's now hehe).
Old Dec 2, 2000 | 05:30 AM
FAST4EN's Avatar
Doesn't advancing your timing (5 degrees) make you car run like ****? That's what my mechanic told me when i asked him if he would do it for me. Any suggestions? For the recordbook: he's my EX-mechanic.
Old Dec 2, 2000 | 07:43 AM
Bryan91SE's Avatar
detailed explanation on my website
Check out my site, it has detailed info on how to advance the timing. Look in the FAQ and there is an explanation on how the timing advance works.
I've had mine at 20 for a couple years now.
[Edited by Bryan91SE on 12-02-2000 at 09:50 AM]
Old Dec 2, 2000 | 10:03 AM
FitzMax's Avatar
Hey FAST4EN!!! I like your new sig pic!!
Old Dec 2, 2000 | 10:21 AM
Bryan91SE's Avatar
Well Fast4EN, you be the judge. Get on my site and go to the videos and compare my acceleration to yours. I had the intake, timing, and f pipe modifications on that run, as well as a 240 lb friend in the passenger seat doing the camera. My car runs great with the advanced timing. It's tough to tell an improvement difference, but I did.
Matt93SE
May 24, 2019 02:58 PM
Matt93SE
Apr 8, 2018 09:23 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Team STILLEN
Aug 10, 2015 04:29 PM
