where is the exhaust gas sensor
Old Apr 20, 2002 | 01:46 PM
jaredb03's Avatar
where is the exhaust gas sensor on a 92SE? please help. thanks
Old Apr 20, 2002 | 01:49 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Re: where is the exhaust gas sensor
its screwed into the y-pipe.
Old Apr 21, 2002 | 09:25 AM
rocko's Avatar
I know on the VG it's located just beyond the Y-pipe, but it's easy enough on any car to find the oxygen sensor: Start from manifolds (jack up the car and get underneath - you usually can't see this stuff unless you do) and follow them until you see something sticking out of the exhaust pipe with a wire attached to it. It will have a fitting so you can use a wrench to unscrew it.
Simply unscrew and unplug it, coat the new oxygen sensor's threads with anti-sieze (very important! Most usually have a little bit already but more can't hurt. Use it ONLY on the threads!) and screw and plug it in, making sure to secure the wire if you have extra length.
220k+ A32
Sep 11, 2015 02:18 AM
TheMafia
Sep 4, 2015 08:26 AM
sdotcarter
Sep 2, 2015 09:53 PM
