A simple way to disable ABS?
Old Apr 26, 2002 | 12:11 PM
ymax
Is there something like a fuse that I can pull out to disable the ABS?Or any other simple way? The ABS is acting up every time I brake. I have a 91 SE and have 200K on it now.
Old Apr 26, 2002 | 03:37 PM
vmok's Avatar
Not sure on the Maxima, but on my Ranger, I pulled the ABS fuse. The ABS modulator was going out on the truck, causing the ABS warning lamp as well as the brake warning lamp to light. Because of the fault, the car was dumping braking pressure to the rear.
After pulling the fuse, the rear brakes were actuating again, and the brake warning lamp wouldn't light when driving. But the ABS light it still on.
-V
Old Apr 27, 2002 | 07:34 AM
DaBoxSE's Avatar
I believe if you pull the ABS fuse, there will be other accessories that will also be disabled. The ABS light will stay on as well. I know that climate controls are going through the same fuse. Go figure
mvm062
Nov 30, 2020 09:00 AM
bbsitum
Sep 6, 2019 07:31 PM
leatherneck
Sep 30, 2015 09:16 PM
Djsmaxima
Sep 14, 2015 11:58 PM
maximusrising
Sep 2, 2015 09:55 AM
