TICKING noise under hood HELP PLEASE
Old Apr 27, 2002 | 06:58 AM
1992MAX
My 92 Max has a ticking noise under the hood, exhaust?? Any ideas ? It is annoying !!! THANKS
Old Apr 27, 2002 | 07:03 AM
DaBoxSE's Avatar
Re: TICKING noise under hood HELP PLEASE
Some more info would be helpful. Do you have an SE or GXE? If its and SE, then you may have a faulty VTC, if its a GXE, then it might be broken exhaust manifold studs. When do you hear the ticking? As its just idling, or when you excellerate mostly? Do a search on those two subject and im sure you'll find a lot of info.
Old Apr 27, 2002 | 07:13 AM
1992MAX
Re: Re: TICKING noise under hood HELP PLEASE
I have a 92 GXE it sounds exhausty, but cannot be sure if it is gaskets, donut, etc. It ticks all the time.
Old Apr 27, 2002 | 02:53 PM
matt1sd's Avatar
Re: Re: Re: TICKING noise under hood HELP PLEASE
go here, it will answer all your questions.
Old Apr 27, 2002 | 06:07 PM
davis4005's Avatar
If it's a really small tick that can be heard more as you put your head towards the fuel injectors, then it could be those also. Check the things mentioned above also.
Old Apr 28, 2002 | 03:48 PM
Bman's Avatar
Could be:
-broken exhaust studs (sound will change volume, sound, etc as engine warms up)
-valve lifter(s) shot. Loud ticking, not too sure what else... maybe performance loss. Hope it's not this.
-fuel injectors. If it's fairly quiet and only really noticable if you open the hood, it's normal. They tick lightly as they open and close.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
leatherneck
Sep 30, 2015 09:16 PM
