Brake Squeal, yeah I searched
Old Apr 28, 2002 | 12:43 PM
molehill84's Avatar
Hey guys,
I know that this question comes up a lot for Maxima's, I just got done doing the search. But to everyone that has a 3rd gen whose brakes squeal, what did you do about it??? If you are just going to tell me to search, please just keep to yourself, thanks. I'm thinking of buying new performance drums and rotors. I'll do anything to get rid of that brake squeal. When it rains, or is wet out, it is unbearable how loud they squeal . It's embarrasing to have a sweet car, but then to hear the brake noise when you roll up
Thanks, later,
Joel
Old Apr 28, 2002 | 12:52 PM
93max's Avatar
maybe stupid but when did u change ur brakes? if their good maybe it wasnt put on right. mine a sqealing too but im just gonna replace all pads (just changed the 2 months ago) and resurface all my rotors cause my steering wheel hella shake when i come to a stop.
Old Apr 28, 2002 | 01:06 PM
Matt93SE's Avatar
STFU n00b!
that only way to get rid of the squeal of the drums is to get rid of the drums.
I went through 2 sets of drums and about 5 different brands of shoes and nothing fixed them.
search for "rear disc conversion". lots of useful info there.
Old Apr 28, 2002 | 10:59 PM
maxdout92se's Avatar
i have this same problem, I have a ve though (no drums)!! My brake pads (da green ones) are brand new and i have squealing as well as a whole lot more brake dust than ever b4. My brakes squeal even when i'm not applying the brakes!! Don't really know what to do about it, but I'm trying my best to wait for my rims so i can do the big brake upgrade, but until then, squeal mobile will be running wild!!
Old Jun 26, 2002 | 07:05 AM
Minimalmaxima's Avatar
at least on of my Brakes squealing without my applying them
I think at least one of my brakes is squealing when the brakes arent' applied. How do you stop that??
Old Jun 26, 2002 | 07:18 AM
Michael's Avatar
Back in a 3rd Gen.
Re: at least on of my Brakes squealing without my applying them
if it is constant then you may have a stuck caliper up front or wheel cylinder in the rear (if you have drum brakes)
or you just may be down to the end of your pads and the wear indicator is rubbing occasionally.
you may even have a warped rotor.
You just need to take a look at the brakes and see whats up.
Old Jun 26, 2002 | 10:05 AM
tilt's Avatar
Re: Re: at least on of my Brakes squealing without my applying them
Would you know which way to place the brake pad (the one with the metal tab sticking out on one side) for the wear indicator to work properly? or does that piece even have anything to do with the wear indicator?
Old Jun 26, 2002 | 10:09 AM
Jeff92se's Avatar
I'm needing a caw
Yup could be the pads are worn down to the wear indicators(if so equipped).
Squeal is high frequency vibrations. You can either try to dampen them or eliminate the source of the vibrations. Both discussed before.
Old Jun 26, 2002 | 10:10 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Re: Re: at least on of my Brakes squealing without my applying them
metal piece..wear indicator
goes on piston side of brakes.
Old Jun 26, 2002 | 10:15 AM
tilt's Avatar
Re: Re: Re: Re: at least on of my Brakes squealing without my applying them
Thanks, the piston-side upper corner? Just Brakes put it on the outer side which was confusing me.
Old Jun 26, 2002 | 10:17 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Re: Re: Re: Re: at least on of my Brakes squealing without my applying them
the rotor and the brake pad is curved a certain way.
it only fits a certain way...i've see the clip on top and i've see the clip at the bottom.
just install the clip pad on the piston side and you'll be fine.
Old Jun 26, 2002 | 12:35 PM
bill99gxe's Avatar
Evil Administrator - "The Problem"
But performing the conversion actually yields nice, quiet results with the right pads
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
