Axle problem ?
Old Apr 29, 2002 | 06:14 PM
MAX420's Avatar
Axle problem ?
Sup everybody......well I've been having a weird clunking noise the past week, It started off as i knock when i would engage 1st gear and step on the accelerator, i would get a weird clunk when the car would start to move from a dead stop.....since then the clunking has went away from dead stop, but now it clunks really bad when i shift from 1st to 2nd kind of aggressively, and when I make a left turn....Before this I used to be able to chirp really easily from 1st to 2nd, now its like a drag to do so and really doesn't chirp unless I rev the ***** out of it, Any assumptions or answers are greatly appreciated, Thanks.
Old Apr 29, 2002 | 06:30 PM
crazy4maxima's Avatar
you are corect sir..
one of your axles are bad.. same thing happend to me, although i knew that both cv boots on my axles were broken, then at the ttrack when i returned to thepit i heard this whirl/ clucking sound when i made a turn, HAd my axles changed by a family friend for 200 for remanufactored axles. Total for labor and both axles for me was 200.. a steal.. but i have to be warey with the remanufact, as when theg changed it the first time i got a defective one. I think as most others do a search for axles, they are some place that make new ones, but are expensive, next step is to go to a junk yard and get it off another maxima, or get the remanu, Good luck, and get this taken care of before more damage can occur to the tranny, imho..
Old Apr 29, 2002 | 06:59 PM
davis4005's Avatar
My car does exact same thing, except I've got an automatic and it actually make it slip. It seems to only happen when it's cold, and I get a lot of slack when I press on the gas, and same thing with left turns, it feels like it's binding up underneath. I've tried to diagnose it, but I havn't found anyone with the same problem. It's just started doing it on the right turns. It just started when I replaced my transmission. If anyone has more information or has had this happen let us know. Also once you change them, let us know how it works.
Old May 1, 2002 | 07:01 PM
davis4005's Avatar
Max420, does your car feel like it is binding up underneath, when you are accelerating during a turn? Does it feel like there is slack when you accelerate from a dead stop? I'm very interested because it sounds like we have the same problem but I havn't found anyone else with the same problem.
Old May 1, 2002 | 07:06 PM
MAX420's Avatar
Yes, it feels like there's a slack when moving from a complete stop.....this is ticking me off....i cant figure out what the problem is.....
Old May 1, 2002 | 07:10 PM
davis4005's Avatar
I think I might just replace them, since it's only like 120 for the pair. I'll let you know what happens.
Old May 1, 2002 | 07:11 PM
yes sir my friend
you need new axles
and badly. Go to http://www.raxles.com ask them for some prices.. also look under the site map.. there is a link to some problems that causes the symptomns..chekc it out ... Get it fixed asap.. you dont want to be on the road with a bad axle... just like the slave that gave out.. be carefull.. it can break and pull to one side and then your in trouble bro.. dont want you to get hurt... Please fix it..
edit-internet address
Old May 1, 2002 | 07:20 PM
http://raxles.com/trouble.htm
Old May 1, 2002 | 07:25 PM
davis4005's Avatar
Sweet, thanks for the link Crazy4maxima. I think it's the inner joint because shuddering best describes it. I'm going to replace them this weekend.
Old May 1, 2002 | 07:32 PM
no problem
I just dont want you guys to get hurt for something that can be taken care of in less than 2 hrs... Max420 bro, do the same... change them,i know that i had a bo\usted boot on my cv joint... but its best to change the whole thing... and make certain that they give you some warrenty...
Old May 5, 2002 | 07:06 AM
davis4005's Avatar
Changed the axles on Saturday, took my time and it took about 4 hours. The old ones were original, and looked and felt shot, I could push the joints in like an accordian. Anyways, I got the remanufactured ones on and it works great! Fixed the problem, it downshifts smoothly now, and during turning it doesn't bind up. I bought the axles for 64 a piece from Napa with a lifetime warranty and they seemed to be of very good quality. It feels like it has 20 more horsepower also, it's great. Max420, if you havn't done this yet, I know we talked and we had the exact same problem so if I were you I would go ahead and do it. Let us know if it fixes your problem too. Thanks for all the help!
Old May 5, 2002 | 07:15 AM
MAX420's Avatar
Wow thanks a lot bro, well i took my car into my Automotive shop and the instructor took a look at the car, he did a few stuff and said it really wasn't from my suspension, he lifted the car up and checked the ball joints on the each side, from what he told me he assumed that they were in good shape, then he made me get into the car and put it in 1st gear, he told me to push in the clutch and pull it up while in gear and push it back down really quickly, it sounded just like the noise I was hearing, he concluded by saying that he thinks it was the back motor mount, I just don't want to changed the motor mount and still have the problem, i will definitely look into changing the axle, i remember before this problem started, I used to have a large amount of power when I would gun it in first gear, now it feels like I've lost some of the power, I hope when I do change the axle that I would definitely feel the power too, Thanks a lot for your reply.
Old May 5, 2002 | 09:19 AM
like i said before
max420 get it done bro, you'll feel it, i doubt that a simple motormount will take away all your horsepower, mines are all shot you see i still got some pull..... davis4005i am glad that this solved your problem..lemme know how it feels...
Old May 5, 2002 | 01:58 PM
MAX420's Avatar
Re: like i said before
Originally posted by crazy4maxima
max420 get it done bro, you'll feel it, i doubt that a sipmle motormount will take away all your horseepower, mines are all shot you see i still got some pull..... davis4005i am glad that this solved your problem..lemme know how it feels...
Thanks for the info crazy, i'll get it done asap
Mar 12, 2020 12:06 AM
boomerbrian
Oct 31, 2018 10:25 AM
The Wizard
24
Oct 1, 2015 08:47 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
boomerbrian
Sep 2, 2015 03:46 PM
