Timing belt replacement costs
Old Nov 27, 2000 | 09:18 PM
TONY92MAX's Avatar
How much should a timing belt replacement cost?
I have heard really expensive prices (like 5 hours labor)
Is that true?
1992 Maxima GXE
Any opinions?
Tony
Old Nov 27, 2000 | 09:21 PM
Matt93SE's Avatar
STFU n00b!
the job done at a nissan dealer will likely cost you close to $600.
it DOES take about 5 hours of labor to do..
when I bought my car, I made them change it as part of the signing contract.. the nissan shop did mine in 3-4 hours with two guys working on it.
Old Nov 28, 2000 | 02:41 PM
MaximaBella's Avatar
Mine cost about $120...FIND a buddy who can do it...Ive gotten really lucky, my step-dads father owns a mazda dealership about an hour away, so I get work done dirt cheap! I dont know what I'd do without em'
Old Nov 28, 2000 | 09:18 PM
Tick Tock's Avatar
I just had it done at a very reputable dealer. It ran a bit over $400. The belt was about $25 rest labor.
Look over recent posts on the subject for other ideas. I changed the water pump, tensioner, frost plug, theromostat, radiator hoses, drive belts and coolant. Ran just parts more - same labor as just doing the belt.
Old Dec 3, 2000 | 10:44 PM
superdesi's Avatar
I have recently acquired my 91 SE and the guy who sold it to me could not remember if he ever changed the damn belt.
I bought the car at 106K. I shopped around and could not find anyone cheaper than $400. The local Firestone place wanted $600!!!
Then, by luck, I found a Nissan factory trained mechanic who agreed to do it for $250 plus parts. The grand total came out to $398 because I had him replace the water pump and the 3 drive belts.
I insisted on using Nissan OEM parts but he used "Dayco" the belts (found in PeP Boys). He said they work fine.
For the water pump, he used a "Cardone" pump.
However, after this job was done, the car was idling a little rough (around 700 RPM). Especially when I put it in reverse. When I try to use the power windows (or put any sort of electrical load), the idle dips further down.
Does anyone know if this is a timing problem? I thought the timing was controlled by the computer.
Old Dec 3, 2000 | 10:53 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Not sure, but one suggestion.....
I'd stick with <b>Nissan brand parts</b> above all when it comes to maintenece, personally on major things like a timing belt, messing up the timing belt can be a b*tch for your engine and definently your wallet!!
Old Dec 4, 2000 | 04:10 PM
primeevil711's Avatar
$470
I needed a mechanic cuz I had a bad water pump and I figured that I might as well change the timing belt while I spending money. I tried goodyear and those motherf*$%^@s wanted $700, then I hit Firestone and they ended up wanting $670 so i went to my friendly local Nissan dealer and they changed my timing belt,my tensioner, and my water pump for $450 I couldn't belive that the dealer was the cheapest place in town and they washed my car while they had it for 4 hours.
Old Dec 4, 2000 | 04:25 PM
MSK
Timing belt replacement & rough idle
Mine cost about $550 from local Nissan dealer, which included all belts, T-belt, tensioner water pump etc. I was surprised too to see that he did not tried to rob me. However, recently when I tried to get my exhaust studs replaced, he tried to charge me $2100. He said that I need both e-manifolds, y-pipe etc. I am still Pi**ed about it an complained to the service manager but nothing happened.
About the rough idle: I think you should check all vacuum hoses first. then I take it back to the guy and see what he says. Keep us posted so we know what was wrong with it.
MSK 90SE
Old Dec 4, 2000 | 07:11 PM
93 SE's Avatar
lucky me...i got a 93 se that runs on a chain
Old Dec 4, 2000 | 07:50 PM
superdesi's Avatar
primeevil711, what city and state was that Nissan dealer who did all of that work so cheap?
Old Dec 4, 2000 | 08:45 PM
Tom's Avatar
Tom
Belts
I paid $360.06 at Northwest Nissan (Lynnwood, WA) back in April '97 to do the timing belt and the three other drive belts on my car. Labor was $259.60, timing belt was $30.96, and the other belts were $13.66 each and rest in taxes.
PH98I30
19
Jun 13, 2016 02:38 PM
stromm
Aug 27, 2015 04:13 PM
erictown
Aug 20, 2015 08:01 AM
Maxima2010 Prem
Aug 13, 2015 11:34 AM
kirkhilles
Aug 8, 2015 10:53 AM
