Help........AntiFreeze Leak
Old May 4, 2002 | 11:21 AM
SupaMax's Avatar
Hey i need some help....MY antifreeze seeems to be leaking. In the morning I will see a slight puddle under the front pass. tire. I have seen it dripping from a spot. I havent been noticing any odd temps raising in my car while I drive it. Well i just was wondering how much it will cost to get this repair done. Im broke now.Wanting to spend money on mods rather than repairs. Thanks for the help.
Old May 4, 2002 | 02:17 PM
andy90se5spd's Avatar
Re: Help........AntiFreeze Leak
check your hoses. squeeze them, any cracks? also check your water pump inlet housing where it bolts up. the gasket still there? it's the silicone gasket maker type.
Old May 5, 2002 | 09:58 AM
tilt's Avatar
Dripping from what spot? Do you see it dripping from the timing belt cover? If it's coming from there it can be costly because of labor. If that's the case you should probably change the timing belt while you're at it too. Antifreeze + timing belt over time is prob not a good thing.
Old May 5, 2002 | 10:03 AM
SupaMax's Avatar
yeah i can see it
Yeah i jus looked today and I can seee it dripping for the space under all my belts and stuff... Im bringin it to my mechanic tomm to see whats the deall and how much it will run me. Hopefully not to much.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Mar 12, 2020 12:06 AM
JoshG
51
Sep 21, 2015 10:41 PM
followthadollar
Sep 17, 2015 06:31 PM
