do these coils need to be replaced (pics)
Old May 11, 2002 | 08:37 PM
poorcollegeboy's Avatar
http://www.geocities.com/quocamolie3/coil1.jpg
http://www.geocities.com/quocamolie3/coil2.jpg
http://www.geocities.com/quocamolie3/coil3.jpg
http://www.geocities.com/quocamolie3/coil4.jpg
http://www.geocities.com/quocamolie3/coil5.jpg
you have to cut and paste them on a new window.... geocites is retarded.
i'm having a surging problem and wonder if this could be the problem. i know a cracked coil has to be replaced, but i'm not sure where the crack has to be. thanks.
Old May 12, 2002 | 06:54 PM
eric93SE's Avatar
Those are some sorry A$$ looking coils
God daaaammmnnnn, I have never seen coils in that bad of shape.
See What kind of price you can get from these guys, through the org:
http://forums.maxima.org/showthread.php?threadid=64024
Old May 12, 2002 | 06:57 PM
crap
thanks.
Old May 12, 2002 | 07:12 PM
eric93SE's Avatar
You'll be real happy when you replace them, Wait and see...all the power you've been missing .
Your replacing all six right!!!
Michael's Avatar
Back in a 3rd Gen.
Re: crap
Mine looked just like that (just on the front bank the rears were ok) and I could pull them up and hear them arcing. for temporary use I wraped them in a layer of electrical tape (tight fit so only room for one maybe two layers of tape) and then when I pulled them up I didnt hear the arcing so it fixed it. I would replace them though this is only a temporary fix to get you by until new ones come in.
Old May 12, 2002 | 08:06 PM
i am a poor college boy
is it necessary/recommeded to replace all six? i was only going to replace only the cracked ones (front three).
also awsm66: do you have to use some kind of special electric tape b/c of the heat?
Old May 12, 2002 | 08:25 PM
pearl93max's Avatar
How can i check my coils...not sure what they even are or do....just that eric93se said you'd be getting some power back!!
-blake
Old May 12, 2002 | 08:40 PM
Michael's Avatar
Back in a 3rd Gen.
I just used regular electrical tape...that is why I say temporary use because of the heat.
I just replaced the front 3 because the back were in perfect shape.
I guess you should replace all of them though.
Old May 12, 2002 | 08:54 PM
any noticable improvements?
any improvements? were you having any problems?
Old May 12, 2002 | 09:13 PM
Michael's Avatar
Back in a 3rd Gen.
Re: any noticable improvements?
sometimes I would have a speratic miss and it went away after I taped it and I didn't notice any improvenent over the tape and new coils (the problem was solved in other words but I didn't have a power increase)
Old May 12, 2002 | 09:29 PM
pearl93max's Avatar
Old May 12, 2002 | 09:36 PM
Michael's Avatar
Back in a 3rd Gen.
Originally posted by pearl93max
is that for my post or for your question earlier.
I dont know how to check the coils without checking a manual...
if my last post was confusing.
I had some problems because of cracked coils...I taped the coils and the problem went away.
I replaced the coils shortly after I taped the coils and I didnt notice a diference from the taped coils to the new ones but again the problem was already cured with the taping of the coils.
Old May 13, 2002 | 07:45 AM
CandiMan's Avatar
Say Candyman 5 times
Thank you
Originally posted by awsm66 is that for my post or for your question earlier. I dont know how to check the coils without checking a manual... if my last post was confusing. I had some problems because of cracked coils...I taped the coils and the problem went away. I replaced the coils shortly after I taped the coils and I didnt notice a diference from the taped coils to the new ones but again the problem was already cured with the taping of the coils.
Just like you guys I have crack coils, just as bad as the pics posted above. Just by looking at my coils you can see signs of arching. I too did the temporary repair with the electric tape, and all went well. I recently rebuild both my VTC's, larger 65mm TB, custom port match intake plenum and manifold and most important bump my ign timing up to 25 deg. I must say for a auto my off line improved greatly, maybe it's due to a combination of all the above work but I would have to think the bump timing had more to do with it. From the day I wrap my coils I knew someday I probably had to replace them, but if there is no performance difference between the wrap coils and new coils my money will be put to other mods
Old May 13, 2002 | 10:54 AM
eric93SE's Avatar
regular electrical tape will not insulate the high voltage comming out of the coil (regualr electrical tape ~600V, coil voltage ~~20,000V). It may prevent the arching to a degree, but it cannot 'fix' the coil in any way. Even mylar or kapton tape is not a fix for the coil. For someone to say that they did not see an increase in performance in shorted coils means that there is more that needs to be done to the car to tune it up.
My coils were not cracked at all, and they had 70k on them, and I saw a big difference in performance when I changed them.
Even if you did insulate the coil from jumping to ground, the coil is still shorting out INSIDE, where the windings are no longer able to create the high voltage b/c the number of turns in the coil is lessened due to the fact that it is shorting out at some point. So you might be getting a small spark barely enough to ingnite your gas mixture. My engine will pull all the way to redline even at part throttle (in power mode).
vingodine
45
May 21, 2016 12:46 PM
kenc15
Sep 25, 2015 06:38 AM
Maxboy23
Aug 21, 2015 11:02 AM
maxima297
Aug 3, 2015 12:50 PM
