what offset is everyone running with aftermarket rims?
Old May 13, 2002 | 01:31 PM
Bucktown's Avatar
just wanted to know. currently i'm running 40mm offset with 5mm spacers on 17x7" rims. was thinking about getting bigger spacers.
Old May 13, 2002 | 01:51 PM
jim90gxe's Avatar
Re: what offset is everyone running with aftermarket rims?
You need spacers for a 40mm offset??
I have a +49mm offset with 1/4" spacer in the rear. I just ordered the +15mm HR spacers.
Old May 13, 2002 | 01:59 PM
maxmizd27's Avatar
42mm 17x7 Ro_Ja's with no spacers.
Old May 13, 2002 | 02:02 PM
Lordrandall's Avatar
I'm running 50 offset with a very small (5mm I think) spacer in the front, and a 1" adaptors in the rear. I have had a bit of rubbing from the rear fenders, but that will go away when I roll them a bit.
I remember you asking questions before Bucktown, and I was going to show you the Spacers at Stillen day, but you took off to Quickly.
Hrmmmmm, Can't post any pics, they are too big. Check my Homepage for pictures....
Direct link to wheel page
Old May 13, 2002 | 02:43 PM
James92SE's Avatar
2 VE's are better than one!
I'm running 45mm with no spacers
Old May 13, 2002 | 07:02 PM
MaDMaX024's Avatar
+38mm offset, 3/8" spacers in the rear...i'm also running 235/45s on 17x8
Old May 13, 2002 | 08:14 PM
JDwyer2821's Avatar
I really Don't know
Old May 13, 2002 | 08:16 PM
dmontzsta's Avatar
Ford Only.
I dont know jack about offset. But, I am running 17 X 7.5 with 235/45/ZR17, and I didnt mess with anything, just slapped them on.
Old May 13, 2002 | 08:27 PM
ngthing's Avatar
+45mm
Old May 14, 2002 | 09:38 AM
pest2001's Avatar
what do u have to do to put on the spacers i just got some new rims and i wanted to put some spacers on
Old May 14, 2002 | 12:43 PM
If those are the new rims in your sig, it doesn't look like you need spacers. Have any side shots?
Old May 14, 2002 | 03:39 PM
pest2001's Avatar
i dont have ne right now but i can get some
Old May 14, 2002 | 06:49 PM
pest2001's Avatar
FRONT
BACK
Old May 15, 2002 | 02:10 PM
Those look good. Do you want spacers because they are rubbing, or because you just want them out a bit?
You could probably get away with very small spacers, like 5mm, without running out of threads on your studs, but not much more. I'd actually rather run without spacers, buy my rear wheels won't even go on without them, and the fronts rub on the strut.
Old May 15, 2002 | 02:29 PM
pest2001's Avatar
yea i just want them out a little and on 2 of my studs on the front passenger side i had to cut some of the tread off because the guy who installed my rims crossed treaded the studs so he cut one on sat. and i just got finished cuttin the other cause i was running on 4 lugs
captchaos
Mar 15, 2016 12:18 PM
I<3 A32's
Sep 10, 2015 11:07 AM
Maxima.KsA
Sep 8, 2015 11:33 PM
JoshG
Sep 5, 2015 10:10 PM
A32goldylocks
Sep 2, 2015 06:39 AM
