do I have the right cai kit?
Old May 23, 2002 | 04:08 PM
lowmax4's Avatar
Ok I have a 92 se (I beleive that's the vg engine right?) I bought a cai kit used off of some guy on here that said it was the right kit. Part of it is allready on the car just not the peice that goes into the fender, a mecanic was allready working on the car so I gave the the cai to him to see if he could put it on and that's all he did. I did a search on it to see if I could do the rest myself. I took the other peice to the car and it didn't look like it was going to the right place and the peice doesn't look the the peice in the write up from the search. The peice has the same basic shap but at one end of it has a slight angle to it, I wish i had a camera but I don't. what I was thinking maybe the guy sold me a kit for a 4th or 5th gen maxima. Hell I don't know, gimmie some input!
thanx
oh one other thing the kit didn't come with the template for the hole what should I do?
Old May 23, 2002 | 04:54 PM
James92SE's Avatar
2 VE's are better than one!
Re: do I have the right cai kit?
thanx
Well you're screwed. If you have a 92 SE you have the VE engine, NOT the VG. From the sounds of it you bought a VG CAI and of course that isnt going to fit.
Old May 23, 2002 | 04:58 PM
D-sta's Avatar
yup you have a VE not a VG. Before buying the CAI kit you could've made sure by using the SEARCH FUNCTION!. Now you have to deal with returning it and waiting for the new CAI.
Old May 23, 2002 | 05:02 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
guys I doubt he has the VG kit because he said "part of it is already on the car" and there is no way any parts from the VG kit will fit the VE.
I think he has the TB to MAF pipe on, but is just confused by the TB to fender pipe piece and doesn't understand how that will fit into the fender. I know Matt93se has some good pics of the CAI install on a VE he can help, but use the search he has posted the pics before!
Old May 23, 2002 | 06:35 PM
lowmax4's Avatar
ok I know I don't have the vg kit because it has kind of a s shape to it, and this one has a u shape but the end looks different. I looked at the pictures matt93se posted and the tubing just doesn't look the same. I bet it's the right kit I was just being a worry wort. now does anyone know where I can get a template for cutting the hole?
Corey
Old May 24, 2002 | 06:07 PM
matt1sd's Avatar
thanx
how about selling that cai to me, i have a vg.
Old May 25, 2002 | 09:25 AM
blackandwhite's Avatar
To them I'm like an idol
thanx
Are sure you have an SE? Or maybe you have a 91 and it's still a VG. Click on my "Homepage" and see if your engine looks mine. And by the way, that 2nd pipe will defineately not fit without the hole drilled. Did the mechanic know that the hole has to be drilled. Look at the pictures on my site.
Old May 25, 2002 | 09:58 AM
lowmax4's Avatar
it's an se
I know I have the se and it is a 92 so that means I have the twin cam ve, I know this for a fact. And I also know that you need to drill a hole for the second peice to fit I just need the templat for the hole. I'm sure i have the ve ingine because my brother has a 91 se and it has the vg. And I have to have the right kit because the first peice is already on the car so I just need the template that's all.
Old May 25, 2002 | 10:16 AM
Re: it's an se
Call place racing there is a link on my homepage they can fax you the pattern
Old May 26, 2002 | 06:06 PM
lowmax4's Avatar
Re: Re: it's an se
does anyone have a fax machine?
Old May 26, 2002 | 07:57 PM
Re: Re: Re: it's an se
Do you have a fax modem in your computer?
Old May 26, 2002 | 08:02 PM
lowmax4's Avatar
Re: Re: Re: Re: it's an se
I have no idea, how can I tell?
Old May 26, 2002 | 09:48 PM
Re: Re: Re: Re: Re: it's an se
How do you connect to the internet? Do you dial in somewhere, or do you have DSL or a cable modem?
If you dial in, then you have a fax modem. There should be some faxing software somewhere on your computer. You can receive faxes by running that program, and then telling the person to send the fax. The program should receive the fax, and then you can view and print it.
Apr 16, 2020 05:15 AM
Sep 27, 2015 08:37 AM
Pied
Sep 26, 2015 03:29 PM
