light problem
Old May 23, 2002 | 09:50 PM
pezking4's Avatar
light problem
I went out and bought a stock replacement bulb for my fog light. After the fun of getting the screws out of the tightly fitting housing I got the bulb in no prob. Everything looks fine, but when I go out driving I noticed my high beams would randomly come on, but especially this would happen when I applied the turn signal. I was in the low beam position still, but I had to kinda jiggle the signal handle around to get the lights back to normal.
Also, I pulled up to a building with huge windows to check out the reflection of the front end, and it looks like the passenger side (the side I put the bulb in) headlight is dimmer now. Any ideas about whats going on? Thanks guys.
-Les
Old May 24, 2002 | 12:58 AM
ThurzNite's Avatar
i don't have an answer, but i'm wondering why you had such a hassle replacing the bulb. It requires removing 2 bolts, pulling the assembly out, un-clipping the wire harness, and removing 2 screws on the back of the assembly.
How did you accomplish the task?
btw, I just replaced my fog bulbs and adjusted the aiming. Not bad for stock fogs.
Jae
Old May 24, 2002 | 11:16 AM
pezking4's Avatar
The reason this was such a task was because those two screws in the back are really tight and its difficult to fit a screw driver in there. So I needed one of those 'S' shaped screw drivers that can fit in there nicely. But I didn't have one at my apartment so I had to wait till I got home from school. With the right tool its all easy then.
-Les
tsi6001
Oct 3, 2022 10:23 PM
Roymg
Sep 3, 2018 05:10 AM
Samedi
Aug 13, 2015 04:05 PM
kirkhilles
Aug 8, 2015 10:53 AM
yat70458
Aug 3, 2015 01:16 PM
