keyless entry
Old May 25, 2002 | 10:28 AM
90inthemaking's Avatar
keyless entry
Does any body know where I can find the code to put into my car so I can activate the keyless entry? I don't have a owners manual
Old May 25, 2002 | 12:08 PM
dert111's Avatar
first get a flashlight and open the passenger door and slide the seat all the way back. look under the dash and there will be a little brass colored box (in the upper left hand side, towards the door, its way up in there). there will be a label on it that says "Digital Touch Entry Control Unit" or something like it. There will be three lines of code. The line you want is the one that starts with an "S" (should be the last set of codes) and then 7 numbers after it. thats the master key number.
Old May 27, 2002 | 08:44 AM
battleminnow's Avatar
After you get that code, punch ST and then the 7 digit #. The car will give a series of beeps. During the long beep, enter your four digit code. You have to do this while the long beep is happening. Afterwards, you can hit ST, the four digit code, and your doors will unlock. Push the trunk or window button, and they will open as well.
Pete
ah2002
Mar 9, 2016 01:42 PM
flu2000
Sep 14, 2015 12:34 PM
videomano
Sep 8, 2015 03:28 PM
Hailstatejig
Sep 2, 2015 06:52 AM
